Old 10-18-2023, 12:34 PM
79 Phoenix's Avatar
79 Phoenix 79 Phoenix is offline
Default HURST SHIFT HANDLE REMOVAL
Anyone know the best way to remove a factory hurst shift handle?
ID:	621895   Click image for larger version
Old 10-18-2023, 01:01 PM
bhill86's Avatar
bhill86 bhill86 is offline
Take either a nice rigid feeler gauge or I think I used a razor blade, and wedge it between the handle and the little isolator on the drivers side only. Then pull on the handle and it should slip out. May take a bit of trial and error but there is a clip inside that is moved out of the way and allows the handle to slip out when the razor is inserted.
1977 Trans Am 400/4speed (swap)
Brian
The Following User Says Thank You to bhill86 For This Useful Post:
Old 10-18-2023, 01:06 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
This ^ ^ ^
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
Old 10-18-2023, 01:17 PM
79 Phoenix's Avatar
Great! Thanks guys for your help... and the picture!
Old 10-18-2023, 02:42 PM
79 Phoenix's Avatar
I inserted a .01 feeler gauge and it still isn't pulling out. I've soaked in pb blaster and tried different angles with the feeler gauge but no luck. Any other suggestions?
Old 10-18-2023, 03:09 PM
23337 YT's Avatar
23337 YT 23337 YT is offline
The divot in the base of the handle is down the middle. That's where the feeler gauge has to go. If it's been a while since it was removed the penetrating oil will help but it will still require some muscle to get it out.
Name:	Hurst Handle Base.jpg
Check ignition and may God's love be with you. -D. Bowie
Old 10-18-2023, 03:19 PM
79 Phoenix's Avatar
Does the hole in the shifter handle corespond to the first hole in the housing (circled)?
Old 10-18-2023, 03:24 PM
bhill86's Avatar
I’m going off memory but I think the clip is a little further down than the hole you circled.
Brian
Old 10-18-2023, 04:11 PM
23337 YT's Avatar
If you can get the feeler gauge in about 3/4" deep, you should be clear of the locking tab. I've never had luck with a feeler gauge, too bendy. I have an old, cheap, putty knife ground down so it's narrow enough to slide in. Maybe it's me, but they never seem to come out easy. It may help to make sure the handle is pushed down into the shifter body. There shouldn't be much play, but if the handle is pulled upward the locking tab can bind with the divot and make inserting the feeler gauge more difficult.
The Following User Says Thank You to 23337 YT For This Useful Post:
Old 10-18-2023, 04:32 PM
79 Phoenix's Avatar
Thanks! That did the trick! I could only get the feeler gauge down about 1/4" before it would bend. But I had a narrow putty knife like you suggested, put it in about 3/4" and it yanked right out.
Old 06-13-2024, 10:10 AM
79 Phoenix's Avatar
How do you put the handle back in? I would think it should press back and snap in but it doesn't want to go. Is there a trick to getting it back in?
Old 06-13-2024, 10:21 AM
John Milner's Avatar
John Milner John Milner is online now
There shouldn't be any real tricks to putting the lever back in. I put the rubber and metal retaining clips in the shifter assembly first. Then I spray the end of the lever with WD40 or something similar. It should just press back in and snap. They can be a little stubborn.
Old 06-13-2024, 03:55 PM
79 Phoenix's Avatar
GOT IT! I pulled one of the retaining clips out (I didn't know they came out) and slid it onto the handle and then pressed them both in together till it snaped secure. Thanks for your help John!
The Following User Says Thank You to 79 Phoenix For This Useful Post:
Old 06-13-2024, 09:33 PM
4dblnkldude's Avatar
Nice, I use a butter knife.
