Ram Air Series Cam from Butler
I'm having an engine built for my 1969 GTO. Decided to make it a ram air car.
I looked for some 722 heads to no avail and stumbled on to the RAII heads Pictured Last edited by napster; 12-06-2020 at 02:44 PM. |
While I was at it I came across the following new cam from Butler. Thought I would give a try.
Engine will be .60 over and with a 427 stroker kit will equal either 440 or just shy of 440 CID. Compression will be 9.9 and using RA IV exhaust manifolds. Should be an interesting build. |
Thought I would revisit this thread since I found out that there will not be a 427 stroker kit bringing the total CID to close to 440 cubes. The stroker kit is for a 461 that will mostly come in at close to 468 cubes. Opinions on the RA II heads I posted before and the roller cam version from Butler that I posted. Good, Decent or bad?
Thanks, Jim |
The intake/exhaust lift is opposite of what a RA II head generally likes. It will probably run better with a 1.65 rocker on the intake and a 1.5 on the exhaust... Seems like a cool build!
This is a flat tappet Hydraulic Camshaft? Like Factory?
Do not understand the HR at the end of the part number. (HR typically means Hydraulic Roller). Tom V.
Hi Tom, yes that is a hydraulic roller cam. Butler offers a "Ram Air" series of HR cams now.... As you know the Butlers are great with marketing.
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
Hydraulic roller version of the venerable 041 grind will run well with those heads and around 440 cubes.
Kind of what I was thinking.
Muncie m20 and a 4.10 gear w a 28 inch tall tire . Launched it fairly high but didn’t shift it particularly high Ram good and lasted a long time. Was a good combo.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
I was assuming it’s a hydraulic roller from the card?
Hi soupman. Would you mind sharing your cam's make and p/n?
The cam in post number 20 is a Butler custom grind:
https://butlerperformance.com/i-2503...tegory:1272239 The Comp XE lobes used are 3315 and 3316. However they were probably ordered with a "B" suffix code after the lobe number. When ordered with that code the .050 duration will remain the same but often the the advertised duration can be different, typically by 1 or maybe 2 degrees. Similar situation with the lift. .
Would the extra exhaust lift come in handy with iron exhaust manifolds
A man who falls for everything stands for nothing. |
Probably not for a street type application. Eventually if the engine is spun high enough the added lift will help.
Are the heads dated D228? If so production heads are a little more desirable than service heads. Looking at the picture both will be D228.
Look at post #25 by The Boss in the link for the dates of production for the RA II heads. http://forums.maxperformanceinc.com/...04#post5256604 |
Took a look at their new cam offerings. Indeed a Hydro Roller. RA seems only a name!
https://butlerperformance.com/c-1234...by-butler.html Last edited by STEELCITYFIREBIRD; 12-06-2020 at 05:01 PM. |
I end up building quite a few carburetors for engines done there or from folks who have bought parts there.
For quite a few years they pushed a LOT of XE cams and most of their custom stuff was ground on 110LSA's for quite a few years. The XE268, XE274 and XR 276 HR were high on the list. It's probably been 3 or 4 years now if not longer, but after a phone conversation with them about an engine they were dyno tuning I sent them the cam card comparison below. Things have changed quite a bit since then, if anyone is paying attention.......
