O.K., I'll try to get graphs to post later, as there are some interesting details...
But for the answers: 15.40 @ 87mph and 178rwHP (and I believe the rwTQ was right at 265)
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
That ET is pretty good with that rear gear
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Shorter tire height on 15x8's give an effective lower gear ratio vs stock 225 70 height. The extra contact patch of the slightly wider 245's should also has helped. Went through a lot of 255 60's in the early 80's till finally slowed down the problem by running 265-60 NCT's.
Agree, it surprised me! I thought it would be about 16.0. I also thought it would be 160's at the wheels.
The owner and I are planning some upgrades, but we both wanted to get a baseline to compare with. I've never seen any truly independent testing on such an original car, and thought that this might be of interest to some people.
Those are very good numbers for the car as represented. That is about what I would expect from that car with a carefully blueprinted 100% stock engine and transmission. Everything must have been right on that one when it rolled off the line. I remember having no problem with those cars on the street and track with a 66 4 door Ventura 389 2-bbl. It barely ran 16 seconds flat at the track.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
Interesting how the chassis dyno is close the the rated net hp of the 403.
The Following User Says Thank You to ta man For This Useful Post: | ||
What the later Trans Ams lacked in power, they more than made up for it in style and comfort. If you outran me in your bug, I would've shrugged my shoulders and drove off knowing I was driving what I liked, no matter what ET it runs.
the best part was i was a broke teenager/early 20's kid, whipping up on the rich snobby yuppy types that thought their vette (or 3rd gen camaro/firebird) was fast! the other best part was i always had prettier girls in the passenger seat!! |
The Following 2 Users Say Thank You to 78w72 For This Useful Post: | ||
I'll take the hot chick riding with me in my slow ass Trans Am over a "fast" sleeper any day.
Even though the "peak" rwHP was 178, the HP was in the 170-178 range for a rather wide rpm range. It did not look like a normal HP curve. My hypothesis is that the converter and/or sigle exhaust section created a HP bottleneck. A new exhaust system is planned in the coming weeks, then we will retest. Edit, we had a photo of the dyno graph on Kevin's phone. Lots of reflections, and the computer screen was cracked, so I ran the pic through some Photoshop filters to make the graph a bit clearer. Bad photo, I know, but it gives an idea of how flat and drawn out the HP curve is. I'll post a good pic of the graph as soon as I have it.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust Last edited by Lee; 03-12-2023 at 04:30 PM. |
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
Yes sir! Near term plans are to replace the stock manifolds with a set of Thornton manifolds (already purchased) along with a high-flow exhaust system. Our 1/4-mile track will be closed before that can happen, but there is an 1/8 track we can use. We will also go back on the dyno, and tweak the AFR as needed.
So the 79 403 Olds ran 15.40
and your 73 ran 15.70 ? What's in your 73 TA ? Both cars look really sharp ! |
Glad you like how they look, though!
That sounds more like it.
I saw 15.70 on your windshield ... oops |
The Following User Says Thank You to Baron Von Zeppelin For This Useful Post: | ||
LOL!!! O.k., that makes sense. That was just the "car i.d." number for the night!
#38
If you are not intimately familiar with the 403, its 4.351 x 3,385. The mains are windowed to save weight. HOWEVER, you can swap to a 72 and earlier 350 cylinder head <#5 6 7 or 7a> and go from 8.0:1 to 9.5:1 very easily. Two things to do when you do that, enlarge the bolt holes (350 pre 77 was 7/16 and 403 uses 1/2") and also go up to a 2.00 intake valve. That head swap alone is worth a bunch. Coupled with a 222/230ish cam and its a whole different animal. If you need some #7 heads I have a pair of cores for $150. You arent spending much and its a great runner.
Mark Remmel in FL sells a 4.00 small block olds crank, ,the 403 ends up at 478"! Even with your friend's car only having 27,,000 miles, its plastic coated cam gear is 44 years old. I'd tear the front cover off and change it regardless of any other work.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
The Following User Says Thank You to Mr Anonymous For This Useful Post: | ||
#39
Stan
#40
Sand Bagger
playing cat & mouse. Looked like he drove it to the 1/8 ,,, then stepped on it |
