Hydroboost System
I am running a mid range cam 240/246 and have about 13" of vacuum. Currently running Baer Serious Street edition brakes in front and 11" drums in the rear. Has anyone here upgraded to Hydroboost for their low vacuum braking systems? if so, which one did you go with? I have a '66 GTO AT/ AC.
1966 GTO 468 CI. A/T A/C Hood Tach |
I fitted a tallon hydraulics kit to my 69 goat over the week-end, just have to get some new brake line made up today and I'll be ready to bleed and test everything.
Was a good kit all parts supplied, from what I read on the net good company and good product.
Your car must be very fast ! Because you were haulin ass when I passed you in my GTO. |
I installed a Hydratech unit about 7 years ago and it's still working fine.
1967 Firebird Convertible Factory 400/4spd Now 462/5spd Fuel Injected http://1967firebird.atwebpages.com/ |
X2 on the hydratech. Looks great and works even better. Paul at Hydratech is awesome.
Skinned knuckles and empty wallet! Could I be any happier? 66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front). 2002 Ram Air WS.6 convertible Trans Am. Wife's car. |
I just finished my hydroboost upgrade. The car is still under construction though so I havnt driven it yet. The post is under suspension.
73 TA 468 5sp SS 700, 12 bolt moser 373, 4 wheel disk brakes. https://www.facebook.com/media/set/?...7567172&type=3 |
The Following User Says Thank You to niceta For This Useful Post: | ||
I went on the cheap and built mine from junkyard parts. I did break down and get a mounting plate from Tallon however to make it a little easier and cleaner install. Works very well so far. In the middle of my swap I realized I was not running the ideal master cylinder which accounted for my whole problem. If I remember right I was running a larger piston master cylinder than I should have been which made it tough to press the brakes, but as it turns out it was a perfect size to use with the hydroboost so it all worked out. Long story short, you may want to check what size piston MC you have first, maybe you could get a nice improvement with just an MC swap. It just seems that 13" isn't THAT bad for vacuum?
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi. Everything installed, fired up and tuning has begun! |
Like throwing an anchor out the trunk!
http://forums.maxperformanceinc.com/...d.php?t=582077 Post # 17 |
