Best bang for the buck
Are the flow numbers based on 4.15 bore? Any dyno test on a factory block type build-up 400-474cid with the high ports? Seems like these are the heads to get for the stock block guys. Not so sure for the MR1 and IA2 blocks (N/A)since the Tiger flows 400. Hard to say since there is no price for the 370+ cfm high port that I could see.
Now, these heads on an IA2 or MR1 with about 18 lbs boost.....era..1200hp...era.."we need a bigger boat!!!" Thats what I'm talking about!
Systems under stress fail catastrophically |
Tin Indian Performance's sight lists 700 hp and 628 ft lbs. on a 463 CID (stock block?). A 505 CID injun made 903 HP @7500 RPM!
Todd Sedlmeier Who ever thought pinewood derby cars would lead to this! October 2004 HPP Shootout participate http://www.highperformancepontiac.co...out/index.html 86 Grand Prix 535 High Port 8.93 @ 153 65 GTO 433 High Port 12.04 @ 113 |
If you put the 56cc heads on a 4.185" flat top piston, zero decked 455, the compression would around 14/1 according to the Wallace calculator...
Can four head bolts per cylinder keep a gasket in place without failure? Or, does it need to be O-ringed... Last edited by 455firebird1969; 12-03-2005 at 09:08 AM. |
