Old 04-26-2021, 04:53 PM
chaosrob chaosrob is offline
Default Plug to seal factory dipstick tube location
Curious if anyone here has plugged off their factory dipstick location when changing over to a canton pan. If so suggestions are welcome before I machine something for the job. TIA
Old 04-26-2021, 05:24 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Mine was tapped to a pipe plug size and had a pipe plug in it.
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 04-26-2021, 05:30 PM
unfortunately I already installed the pan and would hate to have to remove it. I know what I should do just searching for other options first. Thank you for the reply
Old 04-26-2021, 05:33 PM
firechicken's Avatar
firechicken firechicken is offline
I removed the stick and just screwed an 1/8" pipe plug into the open end of the tube.
The Following User Says Thank You to firechicken For This Useful Post:
Old 04-26-2021, 06:10 PM
Kevspontiacs@aol.com's Avatar
Kevspontiacs@aol.com Kevspontiacs@aol.com is offline
I just put a rubber plug over the end with a hose clamp. That way I still have access to it
The Following User Says Thank You to Kevspontiacs@aol.com For This Useful Post:
Old 04-26-2021, 06:25 PM
tom s tom s is offline
I actually made mine work with a tip from a board member.Too late now I guess for you.Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 04-27-2021, 02:44 AM
lust4speed's Avatar
When rebuilding an engine that we knew a Canton pan with it's own dipstick was going in I cut a 1" long piece of half inch rod and stuck it in the block with Ultra Grey. Pushed it in to the bottom of the hole inside the block and then smoothed more silicone on the outside of the hole to flush it off with the block.
Mick Batson
The Following User Says Thank You to lust4speed For This Useful Post:
Old 04-27-2021, 07:04 AM
ErikW's Avatar
ErikW ErikW is offline
I usually just make an aluminum slug to drive into the hole from the outside.
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
The Following User Says Thank You to ErikW For This Useful Post:
Old 04-27-2021, 07:40 AM
Half-Inch Stud's Avatar
When i plugged the Dip-tube hole; JB Weld and a randon bolt for filler, them masking tape to shape the surface during cure. The Billet Caps motivated the plugging due to inteference with the tube thingy.
I retain the dipstick now. Factory 2- Bolt Mains make the tube thingy rather basic, even wirh SD or Aluminum rods. Really ought to like check it, now.
Old 04-27-2021, 12:35 PM
ta man ta man is offline
I did the same and used the "Right Stuff"
The Following User Says Thank You to ta man For This Useful Post:
Old 04-27-2021, 04:56 PM
BB70's Avatar
BB70 BB70 is online now
I used a small cup plug- freeze out plug.
The Following User Says Thank You to BB70 For This Useful Post:
Old 04-27-2021, 10:52 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Worked great for me - if I have a leak or wonder - I just get out the dip stick!
The Following User Says Thank You to CraigG. For This Useful Post:
