Tranny Starup
So ... TH400 is assembled, attached to the engine on the test stand, new Hughes TC installed, yoke installed, cooling line looped with clear tubing, vacuum modulator installed (no vacuum line), dipstick tube and stick in, and about two gallons of synthetic Dexton in it.
Started the engine, no noises, no leaks, park works, neutral works, yoke turns one way in reverse, and the other way in drive gears, fluid flowing through the cooling lines.
Am I good to install in the chassis? Any other tests I can/need to do first? Don't have the equipment to do any pressure tests.
