my friend has a 65 lemans with ac the current radiator has the hoses on opposite sides but when he ordered a radiator(cold case)the hoses are on one side the car was purchased from an original owner years ago and the only change that we did was to replace the motor with a 400 and still retains the ac system any help is appreciated THANKS
The 65 and 66 radiator hose connections were on the passenger side. Sounds like you have a 67 radiator. This is a common change as having the in and out on opposite sides was thought to have a little better cooling. You can either return it and get a 67, or keep it and get a thermostat housing and upper hose from a 65.
![]() Quote:
64 and 65 radiator hoses (top / bottom) were on the RH side. 66 and 67 radiator hoses (top / bottom) were on opposite sides
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
![]() Quote:
