How to Remove Swirl Marks, Minor Scratches from Paint
The paint on my two '64 GTO's both are beginning to show some very minor swirls visible in certain light conditions. This may sound silly from a person who has been a "car guy" for more than 50 years, but I'm sure some of you have faced the same dilemma. With car show season upon us in the Midwest, I'd like to do the best I can to hide the swirls.
The Grenadier Red GTO is single stage DuPont Urethane with no clear coat. After cut & buff in 2011, there were no visible swirl marks. The Gulfstream Aqua GTO (my wife's) is Ditzler urethane with clear coat. It was cut & buffed in 2016 right after painting, also with no visible swirl marks. What is the best/easiest way to hide the swirl marks? I have used Meguiar's Quick Wax & Surf City Wax Detailer, buffing with microfiber towels after application. This helps, but some swirls remain. I've heard stories of people who use Pledge Furniture Polish, clay bar, etc. to restore a near perfect finish, but have heard mixed results.
Professional products are the only thing to use.
Amen x 2 for 3M professional products.
Some 3m or other brand scratch and swirl remover (I usually use Adam’s) + a Porter Cable polisher with the right foam pad will likely take care of most of the swirls. Clay it before you polish so you don’t grind in any contaminants.
You could do it by hand with the compound but it’s going to take some muscle. http://www.adamsforums.com/topic/287...e-swirl-marks/
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
Every car guy needs this oscillating buffer ...with micro fiber pads and maguires compounds. Anyone can use this buffer without a brain....it’s is so user friendly....you cannot burn through the highest peak on any panel. Been using it for years ....black cars with no swirls ....not a problem. A true god send ! 42 years in the paint and body field and still doing it... I forgot more than I know.. PM me if you want. |
Dick,
There is a guy on You Tube that has a 5 part series of polishing your paint. He is a little 'long winded', but he is very detailed and he makes the process very simple. I have purchased the products he uses, Meguires M105, and M205, as well as a Porter Cable Orbital polisher with the polishing pads.. The process is time consuming, but there is NO WAY of harming your paint with his method, and the results are great. Here is a link to his Part 1 video, .........sit back and relax as it does get tedious. https://www.youtube.com/watch?v=KP-eAddv2sk |
I use Mequires M105 and M205. Wool pad for the 105 and foam for the 205 to cut and buff after new paint. But saying it's not going to effect the paint isn't exactly true. These compounds are just like sandpaper with varying grits. You are removing some material by using them. Take care on edges and ridges, any place where the paint might be thin. If using a rotary buffer make sure the rotation is away from edge, not into it. If it is only swirls as you describe I'd be using a very light compound like the 3M stuff above and using a DA buffer at a very low speed setting. As mentioned previously, make sure that surface is clean or you'll only be putting more scratches into the surface with contaminates.
12.84 @ 106.89 with street radials. 12.63 @ 108.39 on drag radials. |
Clay bars are a waste of time only pushed by paid endorsers. Wash the car, dry it and use the swirl mark remover. What minute so called "contaminants" will come out in the process with ZERO paint damage. But hey, if you have 2 days to waste prior to actually getting the job done, knock yourself out.
The More People I Meet, The More I Love My Dogs! |
Thanks for the responses. I think I'll try the 3M route. That's what the body shop used when finishing the car. I just need to line up a good oscillating buffer.
Same here, but how many body shops do you see use them? Body shops specialize in paintwork.
Oscillating helps if you're not experienced, but speed control is more important. Find one with variable speed. I have a Ryobi. Also, follow the 3M speed recommendations to a "T".
Check out “Chemical Guys” they sell all the tools and have plenty of ‘how to’ videos.
1970 T/A RA3 #'s match. |
After using the buff compounds use a product called "Ebony".
Take them swirls and buff marks right out!
72 Lemans Sport convt., 84 Z-28, 13 Chevy Impala, 94 Buick, 77 Triumph Bonneville |
3M just like Chief of the 60s says. Buffer speed no more than 1500 RPMS
DBANDGB |
Do they still make that? The problem with "Liquid Ebony" is that it leaves black streaks that can be a b itch to remove. It is also very old technology that is far surpassed by the new 3M Perfect-It products.
The OP needs an oscillating buffer.....there is no man on this planet that can buff a car with a “rotary” buffer and not get swirl marks...I don’t care if you use a foam pad...a micro wool pad...Liquid Ebony ( yes I used it in the 70’s ) ....I use a oscillating buffer ..AFTER ...I use the rotary buffer. ....and I have Plenty of experience.
Okay
X2. Otherwise you're not removing swirl marks, you're filling and hiding them. For a while. That's what gets a collision repair out the door. Wash it twice and see if I'm lying. And if you really want to see your results, spray mist a 25/75 mixture of alcohol and water over it and wipe it clean with a micro fiber towel. |
