TCS switch
Was wondering if all 70's came with the tcs switch or was it an early/late thing?
WWW.SUPERCARCREATIONS.COM |
All 1970-74 Pontiacīs, except 1971 455H.O., uses the TCS/SCS system.
My 09E 70 came with it.
Jason |
Got it, thanks. Just confirms my thoughts.
I have an 08B and it has it. TCS is emissions related, I think emissions is always model year specific.
"Having a 10 second Civic must be just like coming out of the closet; you'll surprise some people, but you're still gay" 1970 GTO, 455+.034", 0 deck, Wiseco's, Eagle rods, 60919, Rhoads, E-Heads, 1.65 Scorpions, RPM, Custom Qjet by Cliff, Doug's 1 7/8", THM 400, Gear Vendors OD, 3.55s.........Her name is Blandorf; after a girl I knew once, 'cause she's just Bitchin, always. |
Yes, the TCS system is emission related, and so is the ported vacuum source for the distributor on earlier carbs.
And as whe know, a ported source for the vacuum advance is helpful with a hotter than standard camshaft, and the TCS may be used the same way. No weak fluctuating vacuum at idle with a hot camshaft disturbing the ignition timing, still full functional vacuum ignition advance while driving. Sometimes the emission devices works for you and your engine! |
