Old 06-15-2023, 01:11 PM
misterp266's Avatar
Default Rear main seal
I have both a BOP and a TIP in stock. I’ve never installed either. Motor is a ‘67 400 with a Scat forged crank.
Any preference on which is better? Any tips on installing that may not be covered in the instructions?
" Darksiders Rule "
Old 06-15-2023, 01:21 PM
Mr Twister's Avatar
Mr Twister Mr Twister is online now
https://www.bopengineering.com/viton_compare.shtml
A comparison. I have used the brown ones sucessfully.
Old 06-15-2023, 01:22 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
ive used both, wo issue, as long as crank has no serrations and i don't think a scat does you should be fine with either.
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 06-15-2023, 03:03 PM
leeklm's Avatar
leeklm leeklm is offline
By no means an expert here, but I really like the BOP 2 piece seal. Motor with eagle crank with serated seal area, had 5 years with no leaks. Just refreshed over the winter and re used the seal. Still no leaks.
Only used the one piece seal once, and it had a small leak when ironically using on a crank with smooth surface. Most likely installing error on my part...
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 06-15-2023, 10:17 PM
Half-Inch Stud's Avatar
I've installed a few 2- piece, and 1 1- piece onto the 3.25" mains. Well the 1-piece looks formidable but putting it on ONCE is pretty easy.
Just don't do it a few times, as if you gotta sort-out the Main Bearing Clearances ahead of time....like i did.
Old 06-20-2023, 08:17 AM
Don 79 TA Don 79 TA is offline
has anyone tried nightmare performance 1pc seal?
Old 06-20-2023, 10:48 AM
misterp266's Avatar
I ended up installing the BOP seal.
How does one get a one piece seal over the crank flange?
" Darksiders Rule "
Old 06-20-2023, 11:29 AM
steve25 steve25 is offline
The same way you get rings onto pistions, carefully!
Plus it's a two person job, one to guide the seal into the groove while the other lowers the Crank.
Old 06-20-2023, 02:24 PM
67Fbird's Avatar
67Fbird 67Fbird is offline
^^^ yes on the 2 person part..... You have to slice the seal per the instructions and as stated...CAREFULLY "tweek" it into position.
Old 06-20-2023, 03:14 PM
Dragncar Dragncar is offline
Sanding is required with that one piece. Lots of test fitting, on and off of the rear cap. Seal needs to be centered without wrinkles.
Call BOP and Mark will explain.
BTW, I used a couple of nylon straps and a come along to lower the crank. And it was still a 2 person job.
Old 06-20-2023, 03:31 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
If it`s got serrations on the seal surface, I would go rope seal. Permatex #1 on parting line.
Old 07-05-2023, 02:28 PM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
Arrow
For the record our seals have been used on serrated cranks for 20 plus years with no issues, tens of thousands of them. The only time the serrations are an issue is on aftermarket cranks (like Eagle) where the serrations are deep and aggressive.
We have evolved our install practices over the years. It is important to realize that what varies from engine to engine is the block groove and not so much the crank. Therefore, we recommend to fit the seals (one or two piece) to the block. This is typically done by sanding the OD until either the correct protrusion is achieved (two-piece) or the cut line is fluid (one-piece). If the ends are trimmed the ID becomes smaller which is not Ideal. The instructions are thorough but feel free to call with any questions, anytime.
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
The Following User Says Thank You to Wade Congdon For This Useful Post:
Old 08-29-2023, 01:32 AM
lust4speed's Avatar
Can someone post a photo of a Pontiac crank with no serrations? Later modification on a lathe doesn't qualify.
Mick Batson
Old 08-29-2023, 03:04 PM
Pontiac Performance Author
get the serrations polished off at a crank shop down to flush with the journal.
The Following User Says Thank You to KEN CROCIE For This Useful Post:
Old 08-29-2023, 03:16 PM
Tim Corcoran's Avatar
Here you are Mike, this is a Scat crank I just got from Butler, as you can see the seal area is sooth as a baby's butt.
Name:	Scat Crank2.jpg
Tim Corcoran
Old 08-29-2023, 06:44 PM
lust4speed's Avatar
So pretty - and surprising...
Mick Batson
Old 08-29-2023, 08:04 PM
bluejudge bluejudge is offline
I am curious, why are there serrations on there to begin with. Thanks, Marc.
Old 08-30-2023, 12:06 PM
Joe-Touring Joe-Touring is offline
They were on factory cranks to provide some oil to the ID of the original asbestos rear main seal. Kept the RMS from grabbing the crank, lubed, pliable, etc
67 LeMans, 326, M20, 3.31 12 Bolt
