Block to trans dowel
I'm missing one of the locating dowels, anyone have a part number for them? 1972 400 block to th400.
69 Firebird 472, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 10.90 @123 |
Just pick up a pair from Summit. I was going to pick a set out but figure I'll give you the choice: Summit Racing dowel pin selection
Thanks. I saw those but wasn't sure if there was a specific one I needed.
Now I can assign a Lakewood Bellhousing to each of the 4 blocks I have: Production 455 block, 9.5" short deck block, 10.240" aluminum block, and 11.000" cast iron tall deck block. I was going to sell the other bellhousings but will now "paint code" a block and bellhousing combination. Great link. Thank You lust4speed. Tom V.
Am I blind or is there no link in this thread? Are the offset dowls w the weld on bung for when you dial indicate the bell housing? I’ve done that on my stick shift race cars.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
If you click on my Post #4 of this thread the Summit link takes you right to the parts.
Tom V.
I just did this LAST week....the offset dowels from RobbMC
https://www.robbmcperformance.com/products/dowels.html worked perfectly as designed. |
Genuine GM dowel pins. Great guy to deal with .
http://nitemareperformance.com/GM%20...el%20pins.html |
