Old 06-08-2022, 06:00 PM
alanmay0 alanmay0 is offline
Default serpentine belt system
Has anyone installed a serpentine belt system on there 1967 GTO with after market AC? Wondering which system you went with, the cost, and the extra parts you had to buy such as ac compressor, power steering pump. ete.. Thanks
Old 06-08-2022, 06:49 PM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
Which timing cover you have?
8 or 11 bolt water pump?
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
Old 06-09-2022, 07:43 AM
chuckies76ta's Avatar
I bought the CVF 8 rib serpentine system for our 68 Firebird. Very happy with there product. Had a issue with belt sweal at the start. Went to smaller belt fix that. They do not use a belt tensioner. Adjustment is done with Alternator and power steering. I went with a new power steering pump with the nut and key way on shaft. Easier to remove than the press style pulley. Product made in USA.
https://www.cvfracing.com/pontiac/
https://www.tuffstuffperformance.com/
Old 06-09-2022, 09:50 AM
you talking about the water pump. the water pump is 11 bolts
Old 06-09-2022, 12:51 PM
78MayanW87 78MayanW87 is offline
You might check out Mike Montanari's YT channel Fast Monty's Garage. He has a '69 GTO that he installed a March system on and has A/C, PS. They are pricey but look fantastic and he seems to really like it. He has a video dedicated to the installation of the system as well. Lee
Old 06-09-2022, 06:34 PM
Schurkey Schurkey is offline
Be REALLY CAREFUL with aftermarket accessory-drive systems.
Every one I've ever seen looks like it was "engineered" by a high-school kid. Poor belt wrap, too many idlers, failure to use an automatic tensioner even though the OEMS have used them successfully for forty friggin' years...the list of potential problems goes on.
Old 06-10-2022, 09:29 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
It seems like the older March serpentine kits for Pontiac had a strange pulley adjustment didn't really change belt tension as the pulley moved; have they reengineered that?
Mike
Old 06-10-2022, 11:13 AM
65madgoat's Avatar
Billet Specialties makes the cleanest looking kit... the main bracket is nice and low and keeps things really clean. Expect to pay close to $3500 for it all though!
ID:	592566   Click image for larger version
ID:	592567   Click image for larger version
Old 06-10-2022, 03:46 PM
roy381 roy381 is offline
My buddy has the Billet specialties also. And had no issues with pulleys lining up. Very nice kit!
Thats a lot of $$$ for some "BLING" you can hardly see though! lol
Old 06-10-2022, 03:56 PM
65madgoat's Avatar
Ha. No doubt. But not seeing a big air conditioning compressor hanging up to the left is part the allure. Tucked tight and low.
And you get to run a better/newer style power steering pump. The thing with Billet Specialties is their main mounting bracket is low and not top heavy.... so you see less of it and the accessories, and more of the motor.
The best front runner version out there by far.
Old 06-11-2022, 08:40 AM
65madgoat, what did you use on your firewall? Just bodywork or a piece of sheet metal?
That looks great!
Old 06-11-2022, 01:40 PM
West Coast GTO's Avatar
West Coast GTO West Coast GTO is offline
Not to hijack this thread but 65 MadGoat, where did you run your a/c lines? Through the fenderwell?
Old 06-11-2022, 03:57 PM
65madgoat's Avatar
That goat's firewall was welded with a firewall kit from DSE or someone and then smoothed.
A/C lines run behind the fenderwell and into a bulkhead in the firewall. How pretty much everyone does it to conceal the 4 hoses.
Old 06-12-2022, 10:11 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
wow there 65...thats quite nice. I fortunately have the skills and resources I made mine using junkyard pulleys (Ford Taurus and Mustang...) as I could NOT keep the v-belts on when i twisted up the ol 400. Mine doesn't get that low and recently discovered that when I made it (car was fuel injected) that i put the power steering pump too low to run a mechanical pump.....which my new motor is currently running (because I don't have an OLD laptop to run XP to talk with the ECU...always something)
