Old 09-23-2023, 10:02 PM
mysticmissle's Avatar
Default Anyone seen a piped line from the front of a two barrel?
Car is a 68 Firebird It has a 1/8” line coming from the front of the car I assume it gets a line to the air cleaner but I doubt it’s factory what is it?
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 09-23-2023, 11:26 PM
77 TRASHCAN's Avatar
Some of that old stuff, that pipe went to the vacuum advance...
Shut it off
Shut it off
Old 09-23-2023, 11:29 PM
You think it’s factory?
1964 540 gto
Old 09-24-2023, 12:40 AM
My 67 Chevrolet Bel Air, 283 2G (the small one) had such a pipe.
Shut it off
Shut it off
The Following 2 Users Say Thank You to 77 TRASHCAN For This Useful Post:
Old 09-24-2023, 07:19 AM
Was that car from CA originally?
That location on the carb is usually where there’s a Ported vacuum nipple, so it’s kinda odd to me that there’s no nipple, but a brass adapter, but who the hell knows?
Old 09-24-2023, 02:47 PM
I don’t believe it to be a cali car but don’t know
Probably won’t get the phs
1964 540 gto
Old 09-24-2023, 03:33 PM
misterp266's Avatar
It looks to me as if it goes into the fuel bowl area. Seems added. Take the top off and have a look.
" Darksiders Rule "
Old 09-24-2023, 03:45 PM
shaker455's Avatar
That's spot below the bowl is generally used as a ported and full vacuum source and never seen it used to power a PCV.
That's someone own rigging.
Servicing the Pontiac community over 20 years
The Following User Says Thank You to shaker455 For This Useful Post:
Old 09-24-2023, 06:53 PM
geeteeohguy's Avatar
I agree. Vacuum advance line that is home-made and oversized.
Jeff
Old 09-24-2023, 07:09 PM
Ok but Why lol thanks guys!
1964 540 gto
Old 09-24-2023, 07:43 PM
Sirrotica's Avatar
FWIW, vacuum modulator source would be my guess, depends on if it's manifold vacuum, or ported. You'd need manifold vacuum for a modulator to operate properly.
As has been said, I have seen hard lines in the mid 50s engines to operate the vacuum advance, but by the late 50s, early 60s the factories had pretty much gone to hose connections. Also on truck applications I have seen hard lines used for distributor vacuum advance, with just a short piece of hose before the advance can so the distributor timing could be set.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 09-24-2023, 08:11 PM
I guess if it probably was added when the turbo 350 was added it makes sense thanks again
1964 540 gto
Old 09-25-2023, 05:52 AM
I have factory vac line routing diagrams around somewhere, but they may only go back to 1970.
I will dig around later and post if I have them for 68.
Old 09-25-2023, 10:19 AM
pfilean's Avatar
pfilean pfilean is offline
Really looks like the proper location for a ported advance. Tube was probably originally rotated to bend up then down before going toward the firewall. And if the carb was originally off a Chevy that would be the proper location for the advance diaphragm.
Old 09-25-2023, 10:51 AM
Kenth's Avatar
Kenth Kenth is offline
Carb is a 7028071 used on a 1968 Pontiac 350 Firebird/Tempest M/T from factory.
In 1968 GM and others started retarding ignition timing by using a ported source for the vacuum advance to heat up the cylinder heads to reduce NOX emissions and this is what the tube in picture is used for.
Someone has twisted the tube but the end of it should point to the distributor.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-25-2023, 11:03 AM
Shiny Shiny is offline
Did this go to another valve like the TCS system or was it direct to the vacuum modulator?
You note the carb is correct for M/T. Did they use the same ported vacuum on Auto cars? Just curious..
Old 09-25-2023, 04:54 PM
Kenth's Avatar
Yes, but for 1968 and 1969 the valve is the T.V.S. valve next to thermostat housing.
All 1968-69 carbs uses the ported source to control vacuum advance, M/T or A/T.
ID:	620533   Click image for larger version
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 09-25-2023, 08:50 PM
Thanks Kenth, that's interesting.
