head gaskets on a 326
i am in the process of doing a oki rebuild on a 63 326.
the previous owner use the worst oil that can be used. sludge throuout the whole engine!!!! i hot tanked the block, installed new cam bearings, had the crank turned .010. new bearings, and new rings. i took the heads apart, hot tanked them as well ( for 3 days) new cam, lifters, timing chain, yadda yadda yadda. i got the lower end back together and tried to bolt the heads up. the head gaskets i got from summit stated that they were for 326, 354, 400, and 455..WTF????? i got @ a 3.72" bore on the 326, but the head gaskets are over 4.2" is it ok to run this engine with these big gaskets? do they make 326 bore headgaskets?
i had a chevy engine once, then i got a pontiac |
Just about everyone has gone to the generic style gaskets. Made to fit any year & bore. I would suggest looking on Ebay for an older victor gasket set for the 326/389. That is just about the only way you will get a gasket that is close to what You need. I will check tonight when I get home & see if I have any.
Keith
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
