Old 03-31-2016, 09:09 PM
Boiler Boiler is offline
Default Anyone sell RA IV pushrod guide plates?
I'm looking for a set for a 70 RA IV but can't find anyone who sells them.
Old 03-31-2016, 09:37 PM
GRX's Avatar
GRX GRX is offline
http://www.compperformancegroupstore..._Code=PontMisc
Old 03-31-2016, 11:37 PM
jm455ho's Avatar
jm455ho jm455ho is offline
I have a set of guide plates and pushrods. Used. How much are they worth?
www.hobracing.com
Old 04-01-2016, 10:53 AM
Old Man Taylor's Avatar
Those are the wrong size. The RAIV pushrods are 11/16" in diameter. If all else fails you can widen the gap in the standard 5/16" guide plates.
Old 04-01-2016, 11:06 AM
Wink
11/32".
Old 04-01-2016, 12:30 PM
Richie Hoffman's Avatar
Richie Hoffman Richie Hoffman is offline
I have 2 sets of 11/32 guide plates call me 516 316 -5914
2008KRE Q16 Winner
2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam
Hoffman Racing building and racing Pontiacs for 35 years
Old 04-01-2016, 12:32 PM
wheneaglesfly wheneaglesfly is offline
I have a full set of RAIV Guideplates, 11/32" pushrods, Special Longer Rocker studs also used on the RAV, 1.65 Rockers with 7/16" pivot balls, Dual Jam Locknuts, & Upper oil deflectors, & Thin lockdown nuts.
I don't want to sell.
I know rhe Value is more than $5.00 bucks.
I used them Racing in the past.
Took the action with virtual no wear.
Upgraded to Crower Enduro Stainless Rockers.
Old 04-01-2016, 12:58 PM
11/32".
Thanks for the correction, 11/16" would be pretty big.
Old 04-01-2016, 01:07 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I know back in the day HO Racing talked about just using a 11/32 pushrod shoved in the 5/16 "stock" guideplates to enlarge them.
Skip Fix
Old 04-01-2016, 01:08 PM
Smith Brothers will make You 11/32" pushrods.
Even get them in Titanium .
You need $$$$ for Titanium pushrods.
BBC Corporate Race Loves Titanium pushrods.
Not really needed in Poncho Pontiac V8.
Valvetrain toss weight is light.
Modern Race heads have huge valves.
2.30-2.500" intakes.
I tried making 11/32 "pushrod guide plates from stock 5/16.
The guideplates broke in my Bench vise.
Super hard Carburized steel alloy.
Old 04-01-2016, 01:33 PM
77 TRASHCAN's Avatar
77 TRASHCAN 77 TRASHCAN is online now
Wouldn't have to worry about them bending!
Shut it off
Shut it off
Old 04-01-2016, 02:14 PM
Skip Fix's Avatar
FWIW the Melling style 11/32 pushrods are not very strong. I bent one just spinning motor over by hand when rocker got in a bind! Why UI went 3/8" on that RAIV motor.
Skip Fix
Old 04-02-2016, 08:30 AM
Gary H's Avatar
Gary H Gary H is offline
Modify the 5/16 guide plates by taking a old 11/32 ra 4 pushrod and tap it with a hammer into the 5/16 opening. Then carefully "tweek it" back and forth to open it up a little more for clearance for the 11/32 pushrods. I've done it many times and works fine.
Old 04-02-2016, 09:09 AM
mgarblik mgarblik is offline
If push rod length or strength is an issue for you, Manton also makes 11/32" in various wall thickness and any length. Yes the OE 5/16" can carefully be opened-up for the 11/32 size.
Old 04-02-2016, 01:26 PM
Thanks everyone, we picked up a set yesterday.
