RA IV harmonic balancer identification
How can I identify a RA IV balancer vs the std Pontiac balancer? Thanks
I have a NOS RAM AIR IV Harmonic Balancer.
There is only one way to Identity if not in the original GM box. The Inner Hub and Outer Inertia Balancer Ring are Timed together by an assembly line builder. A Line stamped across both. Once the Crankhaft pulley is installed you can not see the Stamped Line. |
I bought it back in 1991 - 92 from an ad in Old High Performance Pontiac Magazine. Days before the Internet. I drove to Wisconsin and picked it up in person from a well known Pontiac Guy. Also bought other rare Poncho Goodies from him. I saved the Original GM Box for over 20 years. It was turning to DUST. I finally threw it out into the trash last year. I do recall the Box had a date code 1975. I am replacing the NOS GM RAIV Harmonic Balancer later this year with an SFI Racing unit I have. THE NOS RAIV HARMONIC BALANCER NEVER GAVE ME ANY ISSUES. SEEN 7,000 + RPMS SEVERAL HUNDRED TIMES. ITS USED NOW OF COURSE BUT SO IS ALL OUR PONTIAC CARS. |
Isn't the RA IV one heavier than a normal stock one?
(never had one, just what I have read)
I was told that NOS IVs had purple paint mark on them.Just helped a friend with one tha was on eBay.I was told also was heavier.Will have him weigh thematic.Tom
Tom nailed it. Purple paint splash and a bit heavier than the regular Pontiac V8 damper.
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
All of the RAIV unique parts that I have ever seen had a splash of purple paint on them.
I recall seeing the purple splash on RAIV pushrods,oil pumps, pistons, etc. Not on lifters or guide plates in my recollection. Dunno about blocks as I never seen a RAIV block in person.
Block caps do
Todd Sedlmeier Who ever thought pinewood derby cars would lead to this! October 2004 HPP Shootout participate http://www.highperformancepontiac.co...out/index.html 86 Grand Prix 535 High Port 8.93 @ 153 65 GTO 433 High Port 12.04 @ 113 |
I also recall today washing it down with Brake Cleaner to get it ready to paint Pontiac Siiver Metallic Blue. The Purple was washed off. Guys are right. RAIV Parts were painted Purple. Like A Dye Paint. My parts have the Purple washed off . I tore down every 2 years to Freshen the Engine. RAIV WAS MADE TO RACE FULL BORE. REALLY COME ALIVE ONCE YOU USE AFTERMARKET RACE CAM . TITANIUM RETAINERS. TITANIUM VALVES. Last edited by wheneaglesfly; 04-01-2016 at 12:52 PM. |
I will remove the RAIV Balancer from TA when I gett time soon.
I have had my hands on many Pontiac Engines. I have seen the Stamped line only on my NOS RAIV Balancer. Not done with a chisel. A special Machinist Stamp was used. |
I was told by engine plant workers that purple was Pontiac's color of choice for identifying special-assembly (high-performance) components on the line.
As far as the R/A IV balancer, it wasn't any heavier than the standard unit. The hub and outer ring (inertia weight) were shared. The difference was the elastomer (rubber insulator) between them. The R/A IV balancer was "tuned" for a higher rpm. The supplier differentiated the R/A IV balancer from the standard unit by adding a paint daub, at least 1-inch thick, over the timing mark. |
This makes sense. I've always wondered about this purple paint dab on the M-21 in my RA 4 car.
It's so cool to see sh*t like that
