Old 03-28-2016, 08:25 PM
Boiler Boiler is offline
Default RA IV harmonic balancer identification
How can I identify a RA IV balancer vs the std Pontiac balancer? Thanks
Old 03-31-2016, 10:07 AM
wheneaglesfly wheneaglesfly is offline
I have a NOS RAM AIR IV Harmonic Balancer.
There is only one way to Identity if not in the original GM box.
The Inner Hub and Outer Inertia Balancer Ring are Timed together by an assembly line builder.
A Line stamped across both.
Once the Crankhaft pulley is installed you can not see the Stamped Line.
Old 03-31-2016, 11:01 AM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
Can you post the part number? and if the box is open post a picture of the line stamping as you described? I'd be interested to learn this also. Thanks
John
Email jbr69gto@gmail.com
My Website www.minnesota-muscle.com
Old 03-31-2016, 11:40 AM
The RAIV NOS GM Balancer is installed on my 1970-1/2 Trans Am right now.
I bought it back in 1991 - 92 from an ad in Old High Performance Pontiac Magazine. Days before the Internet. I drove to Wisconsin and picked it up in person from a well known Pontiac Guy. Also bought other rare Poncho Goodies from him.
I saved the Original GM Box for over 20 years. It was turning to DUST.
I finally threw it out into the trash last year. I do recall the Box had a date code 1975.
I am replacing the NOS GM RAIV Harmonic Balancer later this year with an SFI Racing unit I have.
THE NOS RAIV HARMONIC BALANCER NEVER GAVE ME ANY ISSUES.
SEEN 7,000 + RPMS SEVERAL HUNDRED TIMES.
ITS USED NOW OF COURSE BUT SO IS ALL OUR PONTIAC CARS.
Old 03-31-2016, 06:38 PM
Isn't the RA IV one heavier than a normal stock one?
(never had one, just what I have read)
Old 03-31-2016, 07:53 PM
tom s tom s is online now
I was told that NOS IVs had purple paint mark on them.Just helped a friend with one tha was on eBay.I was told also was heavier.Will have him weigh thematic.Tom
Old 04-01-2016, 09:19 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Thumbs up
Tom nailed it. Purple paint splash and a bit heavier than the regular Pontiac V8 damper.
Regards,
"455HO" Lloyd
Old 04-01-2016, 10:50 AM
Old Man Taylor's Avatar
All of the RAIV unique parts that I have ever seen had a splash of purple paint on them.
Old 04-01-2016, 11:00 AM
Lloyd-TX's Avatar
I do believe that you're correct, OMT.
I recall seeing the purple splash on RAIV pushrods,oil pumps, pistons, etc. Not on lifters or guide plates in my recollection. Dunno about blocks as I never seen a RAIV block in person.
Regards,
"455HO" Lloyd
Old 04-01-2016, 11:03 AM
Block caps do
Old 04-01-2016, 12:36 PM
RA462's Avatar
RA462 RA462 is offline
Thanks for the info. I'll have to check the one I have. I bought a 455 in 1995 and was told the balancer was a RAIV he bought NOS. I remember him telling me the RAIV had a closer tolerance on the balance than normal stock balancers. Anyone know how many grams a RAIV is?
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
Old 04-01-2016, 12:46 PM
I do recall today my Ram Air IV Harmonic Balancer had Puple paint Dye on it.
I also recall today washing it down with Brake Cleaner to get it ready to paint Pontiac Siiver Metallic Blue.
The Purple was washed off.
Guys are right.
RAIV Parts were painted Purple. Like A Dye Paint.
My parts have the Purple washed off .
I tore down every 2 years to Freshen the Engine.
RAIV WAS MADE TO RACE FULL BORE.
REALLY COME ALIVE ONCE YOU USE AFTERMARKET RACE CAM .
TITANIUM RETAINERS.
TITANIUM VALVES.
Old 04-01-2016, 12:50 PM
I will remove the RAIV Balancer from TA when I gett time soon.
I have had my hands on many Pontiac Engines.
I have seen the Stamped line only on my NOS RAIV Balancer.
Not done with a chisel.
A special Machinist Stamp was used.
Old 04-01-2016, 04:28 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is online now
I was told by engine plant workers that purple was Pontiac's color of choice for identifying special-assembly (high-performance) components on the line.
As far as the R/A IV balancer, it wasn't any heavier than the standard unit. The hub and outer ring (inertia weight) were shared. The difference was the elastomer (rubber insulator) between them. The R/A IV balancer was "tuned" for a higher rpm.
The supplier differentiated the R/A IV balancer from the standard unit by adding a paint daub, at least 1-inch thick, over the timing mark.
Old 04-01-2016, 04:41 PM
Ram Air IV Jack's Avatar
Ram Air IV Jack Ram Air IV Jack is offline
This would explain why so many of the aftermarket balancers for Pontiac engines have footnotes reading, "except ram air".
Old 04-01-2016, 08:45 PM
snakepod's Avatar
snakepod snakepod is offline
This makes sense. I've always wondered about this purple paint dab on the M-21 in my RA 4 car.
Old 04-02-2016, 04:55 AM
dataway's Avatar
dataway dataway is offline
It's so cool to see sh*t like that
