So, actually in the end, it really was an issue with the Ign.1 and Ign.2 not both being present.
Think about it, if you had 12 volts in both key positions and it still did not run, the switch and all the ignition wiring were doing their jobs...The problem would have to have been something totally unrelated. Glad you found it and now you know all about HEI, IGN1 and IGN2...
Greg Reid Palmetto, Georgia |
Thanks again all.
1968 LeMans conv. 350 HO - 4 speed triple white (hear it idle here) https://www.youtube.com/watch?v=eVmq...ature=youtu.be 1968 LeMans conv. 350 - 4 speed Solar red/pearl |
The big clue is the classic symptom, it tries to run when the key is in the start position but as soon as you release, it goes dead. It's a very common issue when we change to HEI. Ask me how I know.
If it's the other way around, ie. voltage present only in 'run', sometimes you can get it to start because when you release the key, it gets fire. If the engine is still spinning just enough, it might start.
Yeah, if you go back to points, you are supposed to drop that voltage back down on the 'run' side. Typically about 9 volts if I recall..
9 or so with the points closed, battery voltage when the points are open.
