What is the little water passage at the front of the water crossover for. I am cutting the crossover off and wanted to know if I could just weld it up so it doesn't leak.
that is the way the water bypasses the t-stat until it opens...not recommended to block it off...Bill
If you run a restrictor, then block it off. Or you can drill 3/16th" holes around the thermostat plate for un-interupted flow.
------------------ NOS is like American Express.....You don't leave home without it. http://www.angelfire.com/fl4/pontiacdude428 |
I've been blocking it off for 10 yrs running.
Cam bolt, and a nut..from 4-bolt stud kit, or your favorite 1/2" Lug nut. Wett the assembly with Silicone sealer while installing and tighter. No leaks. I do not run a thermostat. When this bypass is blocked. You cannot run the thermostat....Like the Dude said "restrictor plate". ..I do not run a restrictor plate either. Car does not overheat. Underheat is not likely at 4hours continuous duty at peak torque [highway] or brief 500HP WOT runs [1/4mile]. A properly connected radiator overflow catch-can system is key. Certainly, all the folks here have this jug hooked up.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
