Old 06-10-2022, 11:50 AM
Keith Seymore's Avatar
Originally Posted by Zooguy View Post
Just seeing this
Must have gotten the block off the casting line? I'm not sure what that means is it a good block or not some people are saying it's very thin and weak.
He's referring to the time built.
Engines were cast, machined and assembled in Pontiac Michigan (block, intake and cylinder heads). The final assembly plant was co-located on the same acreage. For cars that were completed in Pontiac one could imagine the engine wasn't totally cooled off before being put in the car.
I exaggerate for effect but, in all serious, the block in my GTO was cast 9 days before the completed car rolled off the end of the line.
K
'63 LeMans Convertible
'63 Grand Prix
Old 06-10-2022, 11:46 PM
Zooguy Zooguy is offline
Okay so now I understand thank you
Old 04-27-2023, 10:29 AM
Revival from the dead but it took a long time but I finally got my build sheet framed. I haven't had time to check behind any other panels to see if there's another sheet somewhere else or potentially one in better condition even but this is what I have so far.
ID:	611584   Click image for larger version
The Following 2 Users Say Thank You to Zooguy For This Useful Post:
Old 04-27-2023, 01:07 PM
Nice display.
Make sure it doesn't get any solar load there which will cause it to decay.
In fact, you might consider making a copy and artificially aging it for display, and put the original away for safekeeping.
That's what I did here (copy of original title in display; original tucked away).
K
Name:	Display redacted.JPG
'63 Grand Prix
