Dyno results...477 cid Pontiac w/ ATI F-2
Dyno results
-------------------------------------------------------------------------- Well, I went to BES last Wed. and dyno'd my motor. The motor is a 477cid, IA2 block, 9:1 compression, e-heads. Here are the results: NA 614 HP @ 6300rpm 590 TQ @ 4700rpm Procharger F-2 1100 HP @ 6400rpm 895 TQ @ 6400rpm The motor still has alot left. These numbers were with 20 degrees of timing. I didn't want to put anymore timing in it because the motor kept going lean. The motor was making 22-23 pounds of boost @ 6400rpm and I didn't want to push it any further. I think the lean condition was a combination of fuel supply and carb issues. I told CSU that I was only going to make 15 pounds of boost and it made 10#s before it even hit the redline. The redline is 7600rpm and I used c16 gas. The CSU carb is kick ass, those guys really know what they are doing. I'm going to put a bigger pulley on the blower to lower the boost, so that I can put somemore timing in the motor. I'm figuring I should probably see another 200+ HP gain when I put the bigger pulley on and give it more timing. I'd like to give a special thanks to the following people: Tony Bischoff and his crew at BES for an awesome motor, Kevin from CSU for a kick ass carb, Mark & Wade from BOP Engineering for bracketry for the F-2, Bruce Maichle for his insight and connecting me to the right people, and everyone who has helped me make this project a reality. Sorry for the short post, but I'm at work and can't post all the details right now.
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) Last edited by bad69bird; 11-08-2005 at 01:47 PM. |
Now we'r talk'n power to spare
bLiNg!
And your going to put all 1100 HP to the ground HOW????
North Dakotas fastest REAL GTO 10.10 @ 131 MPH in the 1/4 Hoping to get it back together some year. www.jandjrepairandrestoration |
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
Wow!! Great numbers congrats!! that ought to be a handfull to drive. lol
Your still short about 500/600hp to compete with the DR boys down here or Orlando. sweat, sweat, LOL. But still awesome and see lots of improvements yet. What class or Organization ya gonna hit? |
Kenny, if I can run in the 8's more then once a year with 940 hp, how fast do you think he will be with 1100??
I will probably keep it local and also go to the pontiac events. I really haven't had the time to research what class(es) I fall into and yet be competitive. -Brian
Yeah man, just pulley it up everytime you go to the track. Start with 800 HP, hmmm next week should I try 900, or go to a grand? Oh my god the fun you're gonna have!
Great numbers, Can't wait to see that killer on the track!!!
LOL. I think Langer was just trying to be a dick. As usual. |
That would be pretty fast in my 1700 pound dragster!
Steve Yea, I know, the heads suck! 2005 Cordova Q16 Winner! 2005 Norwalk Sat Top ET Winner! |
I actually watched Langer's car run more times than your car or Ray's car this year, Kenny! What's up with that deal?
If Jack G. had not solved Ray's ignition deal, I wouldn't have seen his car make any decent passes. Time for you to make a trip from Florida with something and come visit! I agree that the fast DR guys are making more HP but don't run down the man for trying with his new set-up.... Good numbers anyway, and hope the car runs well. Tom V.
great numbers
did you use an intercooler, whats the stroke, standard or wideport heads???inquiring minds would like to know.
Wow, what a combo. One word comes to mind. MONSTER
Are you going to drive this on the street too BadBird ?
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
That's the nice thing about living her in SoCal. Hmmmmmmmmm, should I race in the summer or spring, hmmmmm,,,maybe the fall,,,,,,,,no I think I'll race in the winter.
Just messin wit ya. Your new Injun combo sound awesome man. Good luck at the track and post some pictures of the Injun.
You know it's going to be a good day when you wake up breathing! |
