Old 10-13-2023, 03:12 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Default Silicone sealer for header Flange to head question?
Hey Everyone,
When sealing a header flange to a head which is better Permatex RTV red high-temperature Silicone sealant or Permatex Ultra copper high-temperature Silicone sealant?
Thanks, Craig
Old 10-13-2023, 03:15 PM
I use the copper one. Seems to withstand the heat longer.
Old 10-13-2023, 03:39 PM
CraigG.'s Avatar
I also wonder about the Permatex red RTV that is the Right-Stuff or Ultra-Red that's both have temperature rating up to 650?
Old 10-13-2023, 03:45 PM
mysticmissle's Avatar
i have used a few different types i am a big fan of dow 737 it is the best sealant i have used for almost any application including headers. High or low temp doesnt not seem to matter for header usage. IE copper doesnt matter in my experience.
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 10-13-2023, 08:24 PM
firechickenman's Avatar
firechickenman firechickenman is offline
I've always used Ultra Gray. Several years with no issues. If nothing else, it's not as noticeable with aluminum heads and silver headers.
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
Old 10-14-2023, 02:25 AM
MatthewKlein MatthewKlein is offline
In my experience. Keeping the bolts from backing off is the most important thing. Many companies make kits with clips and washers. The easiest for me was safety wire. I've never had a leak if the bolts were tight.
Old 10-14-2023, 12:34 PM
CraigG.'s Avatar
Over the years of using copper gaskets with sealers and after trying many options of combinations of gaskets - My old machinist planed flat the flange and then I used the ultra copper without gaskets. - mufflers on the street and open headers at the track.
They are leaking now - do using mufflers and the resultant backpressure indicate a more comprehensive approach - like special gaskets, etc?
Thanks, Craig
Old 10-15-2023, 01:12 AM
turbo69bird's Avatar
I always use ultra copper w turbo applications these get crazy hot and have lots of back pressure and it works , regukar headers I’ve never had it fail
960 HP @ 11 psi, 9.70 at 146.
Old 10-16-2023, 09:08 AM
VCho455's Avatar
VCho455 VCho455 is offline
Thanks, Craig
It can't be over emphasized how important having the gasket surface(s) flat and true is to having trouble free headers. No leaks, no loosening fasteners. It's worked for me on Pontiacs, AMC's and Chevies. Race cars and daily drivers.
I use a 4 foot long belt sander to get mine perfect.
Old 10-16-2023, 01:57 PM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
If you are running EFI or a stand alone sensor, Make sure what ever you decide to use, that it says its safe for 02 sensors.
Old 10-16-2023, 05:49 PM
455dan's Avatar
455dan 455dan is offline
Had better Luck just going with Remflex gaskets than multiple tries to seal with sealant a warped header flange. Do have to be gentle with them during install though.
1984 RX7 Jim Hand style 455 /200 4R Project car
67 White/Gold GTO 4 speed sold, 1968 GTO 4 speed sold, 1969 GTO auto sold, 68 Firebird 400 4 speed (455) sold, 65 GTO Night Watch Blue 4 speed sold, 64 GTO Nocturne Blue 4 speed sold, 71 GTO Gold auto sold. 1975 Formula 400 auto sold.
Hopefully to be restored, H-"O" Racing 73 Trans Am SD 4 speed,
Sons 70 Formula 400 auto, and wife's 1974 AMX 360 auto, 1975 Jeep Honcho 4x4, 1965 Buick Special post
Old 10-16-2023, 08:59 PM
John Langer's Avatar
John Langer John Langer is offline
I use red or orange.
Old 10-17-2023, 05:13 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
I've used ultra copper without gaskets.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
The Following User Says Thank You to RAIV-Z For This Useful Post:
Old 10-17-2023, 11:53 PM
I use ultra copper w wide band O2 all the time never had an issue. . Same O2 sensor in my car since 2009
Old 10-29-2023, 01:13 PM
CraigG.'s Avatar
Thanks Guys - I will try this:
Permatex 27038 Optimum Red High Temperature Gasket Maker, 3 oz
Old 10-29-2023, 05:51 PM
CraigG.'s Avatar
The Copper is good Too!
