Old 07-31-2021, 07:05 PM
dataway's Avatar
dataway dataway is offline
Default Dent School
A couple of pics of my trunk lid which will be the first part I fully prepare and prime ... figured it would be the best starting point since it's flat with a simple curve, easy to move around and work with.
Pictured are a couple of dents by the key hole. Wondering how to handle them. You can see the "eyebrow" on the curve in the deck. There is some access to the back but very hard to see what you are doing on the other side. Considered making a custom tool to push from the back but so far most of the leverage points seem too delicate.
Thinking maybe tack on a stud and pull some while tapping down the eyebrow. Worth it to fashion a tool? Or should I pull it? Or use another method?
And what's with the dealerships back in the day ... looks like they centerpunched the holes for the dealer emblem
ID:	570661   Click image for larger version
Old 07-31-2021, 09:32 PM
Formulabruce's Avatar
I would try a round ended tool and get behind it. Gently warm it to around 175 degrees.
The dealer emblem..... sadly thats what we were told to do.
The lowest man / youngest man on the pole usually did set ups. I was careful with emblem holes and did drill, and used a dab of "GMS" on the studs.
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 07-31-2021, 10:07 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
I think you have the right idea with pulling it. Shouldn't take much effort to get those small dents out, gentle tapping around the perimeter with a light tug should do it. May need to finish it up with a shrinking disk If you tug to hard
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
The Following User Says Thank You to n20ta2 For This Useful Post:
Old 07-31-2021, 11:16 PM
nytrainer's Avatar
Stud gun and body hammer
The Following 2 Users Say Thank You to nytrainer For This Useful Post:
Old 08-01-2021, 07:33 AM
dataway's Avatar
Here are some photos from phase one. Did some pulling and some minor tapping. Second photo is the finished product so far. Visually looks great, ruler shows some ups and downs about .020" ... my hands must be sensitive, they feel like mountains.
Going to mess with it a bit more, try to make sure there are no highs on the crown of that curve and call it good.
And I was mistaken, these trunks are not flat or straight, at least not around the lower half .... has a very gentle curve from side to side with the peak being around the key hole and a very slight arch along the bend and for a few inches toward the rear window. Course some of that may be because the deck is not attached to the frame with vibration damping yet.
And after a bit more work.
ID:	570669   Click image for larger version
Old 08-01-2021, 08:36 AM
mrennie's Avatar
mrennie mrennie is offline
Excellent work so far!!!
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
The Following User Says Thank You to mrennie For This Useful Post:
Old 08-01-2021, 08:43 AM
1965gp 1965gp is offline
Looks great!
The Following User Says Thank You to 1965gp For This Useful Post:
Old 08-01-2021, 02:29 PM
dataway's Avatar
I can definitely still feel something, going to check tonight for highs and knock those down and leave the rest. Might still have a couple of tiny mounds left by the stud weld tack.
Old 08-02-2021, 07:16 PM
MUSLCAH MUSLCAH is online now
You need to get one of these body files ….if you want to be a bodyman.. this here tool …will find high and low spots with just a few swipes…while working bare metal .. Then ,when you think you got it….I DA the repaired metal area with 80 grit on a DA….then pass the file over that area again….and look and see what the file marks tell you.
The Following User Says Thank You to MUSLCAH For This Useful Post:
Old 08-03-2021, 02:09 AM
dataway's Avatar
Good idea, just ordered a file and holder.
Thread Tools
Display Modes
