59 Pontiac Mickey Thompson + GM Dept X Aluminum Heads
I came across these interesting experimental aluminum heads on my local Craigslist this morning and thought you all might be interested in at least seeing them. Sounds like they have a pretty interesting history!
https://seattle.craigslist.org/kit/p...350909502.html Photos and ad text inserted below: Quote:
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
The Following User Says Thank You to ZeGermanHam For This Useful Post: | ||
wow, awesome
1972 Pontiac LeMans Thanks to Fuelab Digital Fuel Delivery Quarter-Max Chassis and Racing Components |
Dang that is a thin center wall divider on those ports!
The Following User Says Thank You to Skip Fix For This Useful Post: | ||
this would be awesome on alky injected in a 57 Poncho gasser using a 59 389 block and a 4.5" stroker crank !
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
Are those only 3/8” rocker studs?
3/8 WOULD BE BOTTLE NECK STUDS.
Those look like my 7/16 straight studs I had put into my 64 GTO heads many years ago. Looks like they were drilled but no oil feed passage under the studs to feed the studs and then the rockers & balls. For sure, pushrod oiling. Tom V.
There was already a thread on this heads on this site,non performance small valve heads.There were actually quite a few of them made,I have owned a few sets over the years.WAY over priced for the heads IMO.Tom
Why is the restamping below the cast in numbers a lower number?
Steve,as I recall that is the developmental number.If you look close on the valve cover rails the cc for each chamber was stamped on it as well as the D number.One set I owned came on a complete alu engine(less rotating assm).Mine was unique as the block had a 61-64 bell pattern and every other one I owned and have seen had 55-60.thad a flat 4 bbl intake and a alu timing cover.It was stamped as a 370 but had 3in mains.Was designed to run without sleeves.I found it at M/Ts back in 1964,took me a lot of years to get my hands on it.Put 60 over 350 size sleeves in it.It is running around in a 62 bubble top catalina last I knew.Tom
Looking at the intake face of the heads, there are 3 large holes where the exhaust crossover would be. I get that the larger centered hole is the crossover, what do you think the other holes are there for?
Those 7/16 Studs have a drill-hole in the side for...oiling.
Might be an oval hole entrance for block-head oil flow-up. NO provision for oill drainback except the pushrod holes huh. Last edited by Half-Inch Stud; 07-18-2021 at 09:32 PM. |
