Old 11-27-2023, 12:27 PM
67drake's Avatar
67drake 67drake is offline
Default Lost a rod nut
This is on my ‘62 Mercury 260 V8, but figure the question would apply to any make.
I’m rebuilding the 260 for my Mercury. On cleaning the pistons last night I found one of the nuts had fallen off the bolt. I must not have threaded it on enough when I tore the engine down, or my kid needed it for one of his projects.
Anyway it appears to be a 5/16 24tpi nut. Common enough, but worried about throwing balance off just using a random grade 8 nut. Not to mention since there is no washers on these nuts, I don’t know if a rod nut is something unique? Anyway correct me someone if I’m overthinking it.
Searching the internet I have had no luck so far finding a single rod nut. I’d hate to buy a whole set of bolts/ nuts for one single nut. Any ideas?
Thanks.
13.95 @ 102.1 on street tires @ 4055lbs.
Old 11-27-2023, 12:40 PM
steve25 steve25 is offline
As long as it's a grade 8 nut of the same thread pitch that's all you need to be concerned about.
Of more concern is the rod bolts.
If this round of assembly is the 5th time there getting torqued up and the motor will be buzzedup above 5k then the bolts should get replaced and the Rods resized as needed.
Old 11-27-2023, 08:00 PM
Half-Inch Stud's Avatar
Keep trying to find/buy a single Rod bolt-nut combo for the nut. The Thread class need be 2B or 3B, not 1B. I would guess 3B.
Old 11-27-2023, 08:30 PM
Formulas Formulas is offline
I may have a good used Pontiac stock rod nut laying around or on a stock rod, H,Stud has a valad concern on class of threads
I wouldnt worry to much about balance on a near stock build stock balance tolerances are usually quite wide
Old 11-27-2023, 08:35 PM
His 260 cid Ford engine uses 5/16” rod bolts, so the 3/8” nuts from a Pontiac are of no help.
Old 11-27-2023, 09:00 PM
Sirrotica's Avatar
Time to find a wrecking yard that will allow you to disassemble one of their core engines, and get a nut. Or maybe a engine machine shop that has some stock SBF rods hanging around.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 11-27-2023, 09:24 PM
Johnny406's Avatar
Johnny406 Johnny406 is online now
Grainger
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 11-27-2023, 10:30 PM
Stuart's Avatar
Stuart Stuart is offline
Does ARP sell single nuts?
Old 11-27-2023, 10:56 PM
67drake's Avatar
Well, after mucho searching, I did find this -
https://www.summitracing.com/parts/a...-8602#overview
The rods were resized when the engine had its only rebuild back around 1980. The bolts/nuts are black , similar to ARP. They don’t look factory. But nothing in that link says they’re “rod nuts”.
Old 11-28-2023, 11:09 AM
72projectbird's Avatar
72projectbird 72projectbird is online now
I'd just get another nut, torque it down and call it good. Unless you're winding the thing up to 7000rpm+ I'd says it's fine.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 11-28-2023, 11:30 AM
67drake's Avatar
I doubt this thing will ever be above 4500, maybe 5000. Just a stock rebuild on an old cruiser with 3.00 gears and a two speed automatic.
Old 11-28-2023, 11:48 AM
grivera's Avatar
grivera grivera is online now
If concerned about weight, remove another nut and match the weight
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 11-28-2023, 12:31 PM
Sounds good.
Don't overthink it. Put another nut on it, torque it like you would any other rod bolts, and run it.
1987 Grand National
Old 11-28-2023, 02:55 PM
HWYSTR455's Avatar
Tensile strength on those ARP nuts you found are rod bolt/nut territory. Two most common are 180k & 220k.
Places like Crower sell individual rod nuts.
If you're worried about balance, replace them all with the same type so they at least match. You may not have end to end rod 'balance' but it won't negatively impact rotating assembly balance.
Old 11-28-2023, 03:31 PM
Don’t even waste one heart beats worth of time over any concern about balance!!
Some high end race motor builders intensional over balance or under balance a motor by a easy 3 times more then what a nut that size weighs!
I can’t believe some people are even bothering to mention anything about it.
Old 11-28-2023, 06:28 PM
67drake's Avatar
Thanks guys. I found a seller selling individual ARP nuts, without paying Summits $11 handling charge,so I went with that. I won’t worry about the balance, it was just a question. Better safe than having an “Oh Sh*t” later.
