#221
..... some of this stuff does seem to carry a certain amount of hate behind it, whether it is intended or not, sometimes it just reads that way ..... ..... hell, i thought Langer was hilarious, i expected him to be very difficult to be around from some of what i've seen, and heard from others, i didn't get that at all when i met John, in fact he was extremely helpful and friendly, but, after some of the things have happened on here, recently, i'm sure many would expect him to set me on fire if he had the chance, (j/k) ... ..... not saying that he feels that way, but i'm just sayin', i wouldn't be surprized if others expected that ..... ..... i can personally assure anyone that wants to know, that GreatGTO, is in all honesty, the best friend i have, and i dont have many, i would trust him with my life, and for me, that is saying alot ..... and i promise you guys, who ever you think he is from these threads, you couldn't be further from the truth ..... |
#222
Did you notice the 1.91 60' time? It has to have an effect on the topend MPH. John your car ran 136 MPH with what a high 1.3X low 1.4X 60'? Running 141 mph with the 1.91 60' was really strong. If it were ET that could be a difference of +- .91!!! Right? JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! Last edited by 71 Ventura II; 01-24-2012 at 02:26 AM. |
#223
If people want to attack a new product,any product right out of the gate you wont be seeing more new products for pontiacs. When I first saw the cv1's I knew the foundation was there, its the most important thing when designing or building anything. Give them whatever time it takes to complete R&D like all the other heads have had is what I said from the beginning. If Im wrong I said I would say so after all R&D is complete. After all it is just a street/strip head, the cv2 is the full race version of the platform. Even being a street/ strip head its come a long way hitting 500 cfm in testing.
Car Craft Garage. Automotive Restoration |
#224
"No it is not. The cracked main block I built in Spring of 2007 and ran until September of 2010. I finally tore it down to freshen it up and found the cracked (hairline) main. I then built my current engine which I had dynoed. The engine I have now has more HP than the one I had then. My old engine saw 7200 a few times and is the one that ran 9.90 @ 136 MPH... My new engine has not made 1/4 mile full pass yet as the trans exploded at 1000 ft last yr on my first 1/4 mile test pass... it still ran 10.07 @ 106 mph coasting... The 709 engine is absolutely perfect and in the car now and I would be happy to run it against a comparable built CV-1 stock block/factory 4.210 cast crank 462 @ 3525 lbs any time..." I looked around a bit for this combo being mentioned and this is what I found... "Thought I would share the numbers of my cv-1's. John Marcella of Marcella Manifolds did the port and chamber work. They were flowed on an independent bench. They are going on a pump gas 535 in my 63 LeMans. Mike" more on the same engine... "11.5 compression. 63cc chambers, scat crank and rods, ross reverse dome pistons, solid roller cam 282-290 @ .050 113 centers .470 lobe w/1.7 yella terra's Pro systems carb don't know what size yet Patrick @ Pro Systems is going to send a dominator and a sv-1.Msd ignition blah, blah, blah. Ordinary stuff" Calvin... if I couldn't get 65 more HP with that combination of parts over my little engine I would throw it down the hill... I mean GEEZ, it is only 73 more ci and weighs nearly 100 lbs less...
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
#225
Seems I recall Porosity issues with the first KRE heads, "total junk, never work, blah, blah, blah..." was posted by many on this board. It took some time to finish development and now KRE's are one of the most used and respected aftermarket Pontiac heads. E-heads, everyone screamed bloody murder because it was round port only. Now offered in O and D. Same song, different dance. |
#226
Also, from a product marketing standpoint, there is a school of thought that believes any discussion on a product (as long as it is not related to a fatal flaw) is good. You want people talking about your product, as soon as all discussion stops, so do the sales. Just my opinion, take it for what it is worth. |
#227
JD... even if he spun the first 200 ft the car would still mph... my experience is loss of traction at the hit causes MORE MPH at the stripe so I would hope a car with a 535, more compression, and more cam by .015 @ .050, and 90 lbs less weight could muster more than 5 MPH over a 462 with a set of Junk 314 cfm E-heads in the 1/4...
#228
#229
I posted in the street section where we just made 813 HP with a 10.75 to 1 compression CV-1 535 street engine. Cam is 265/272@.050, steel connecting rods, flat top pistons, standard rockers, .080 wall push rods and off the shelf headers. This combination will fit in a 67 GTO with a stock hood. That's the reason they make bigger heads. Calvin Hill Hill Performance / Mondello Tech Center 708-250-7420 |
#230
I am glad you have finally told people how it is on the common stock block builds... Now, where is it's niche because it's not in the 500+ ci builds either? Power adder head maybe?
#231
Calvin... Is this the rear wheel HP you quoted in your other thread? If so you are incorrect. I know what mine makes at the flywheel...
#232
You want a cast crank? Thats your choice to make. Does his crank really add hp? If both of you upgrade to a larger 535 and say 13.5 compression and race gas or e85, which of you is going to need new heads or spend a bunch more money on existing heads and valvetrain and ported intake (if needed) to beat the other? (No super deal on used parts considered) We all have choices...ours to make...if you dont like one of the choices thats your decision no one elses. BTW pretty sure Arnies stock block 467 cv1 combo makes a whole bunch more power than your stock block NA. Sure it probably has more $ involved... but then again it makes alot more than 709 HP... just sayin. Last edited by BruceWilkie; 01-24-2012 at 12:48 PM. |
#233
Looks like you have a pretty good combination, care to share all of the specs? Calvin Hill Hill Performance / Mondello Tech Center 708-250-7420 |
#234
Question 2 = We were comparing MPH, my 136 at 3525 lbs to 141 at 3435 lbs. Question 3 = With 535 CI I would certainly hope so!
#235
Not sure about that... I heard he has to spray it to start it, that is if it even still runs, haven't heard a word about it in some time... Just Sayin...
#236
#237
I have run 8.93@160 with a 1.52 60 ft'er. But when talking nitrous, Hp is really hard to figure cause all the numbers get out of wack.
#238
You have run 91 octane? What compression for 709 hp?
So... you can get 725 -730 hp from your 467 on 91 octane? Do share details like compression and cam. Quote:
My questions in reference to 535 was... Quote:
BTW, I could be wrong, but I'm pretty sure Calvins terminology for hp to the ground is actually 1/4 mile speed to weight estimated flywheel hp. vs Dyno flywheel hp result. In other words hp at the flywheel made on the run not dyno number made at another time. NOT wheel hp on a chassis dyno. Last edited by BruceWilkie; 01-24-2012 at 01:43 PM. |
#239
Are these the exact same type of car - I have see huge differences in MPH based on how slippery a car is -- when I went from my Willy's to the firebird body it was worth at least 7 to 8 mph -- same drive train and weight was close.
#240
By the way Calvin/Bill said they dynoed on 93 octane so where did 91 octane come from? |
