27 3/8" x 19" was the size of my ventura's stock radiator. I went with a 31" x 19" radiator because I borrowed the motor/tranny and radiator out of dad's 68 firebird, it ran 190ish in his car and would over heat in mine. I guess the frontal airflow isn't that great.
I cut my core support to match the radiator. My temps have never been over 180 since, even driving in this heat and hot lapping the car. |
I have an Al. griffin for mine. Brian I can get the part number off it if you need it or I can measure it.
are you measuring the core only or the total width including the tanks? I believe it's somewhere in the 23-25" core width for a stock X-body regardless of make. The summit universal mount (I forget which one exactly) they sell for $165 would probably fit right in, minus adjusting the pads on the bottom of the core support. I just run a copper 4 core I plan to replace soon because it's getting old!!
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
Brian'74- Did you ever buy that summit alum-rad? I am looking at getting one too but not sure on the size and fit.
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
I think i will be cutting my core support as well as i have about 2 inches on the pass. side which is hidden. Hope it will help in the stop and go traffic. Electric fan is next.
