are they really asa good as they sound? i just made for a purchase i really hope its going to be a great investment. any feedback will be great thanks. Osvaldo
463 Stroker Kit. ross pistons. h beam rods. eagle crank. 62 heads 72cc, port matched Performer RPM-850DP Auburn- 3.55 gear CC HR custom grind |
About 90% of the leaf spring stockers run John Calvert's setup. Thats a lot of racers who made the same decision you did. My experiences with 'em have been rewarding.
CLICK THE LINK AND SEE WHAT THEY DO FOR ME!!!!
RAIV55, thanks. i havent done much work to my engine other than a few bolt on like hooker super comp headers, edelbrock performer, and msd coil and cap, but anyway will the caltracs make the car perform better (faster) just by adding the caltracs over the stock suspension?
Slick1, wow, what is that car running?
I noticed little difference, if any, in 60' times when I installed them on my T/A and still had the pump gas 455 in it that was only good for high 12's at 105-106 MPH. When I put the nitrous bomb in the car however and caged it, they worked great.
[QUOTE=*67firebird*]RAIV55, thanks. i havent done much work to my engine other than a few bolt on like hooker super comp headers, edelbrock performer, and msd coil and cap, but anyway will the caltracs make the car perform better (faster) just by adding the caltracs over the stock suspension? QUOTE]
If the car is hooking up with stock suspension, caltracs probably won't make a huge difference. The gains will be noticeable when you're traction limited and the horsepower/torque exceeds what the stock stuff can effectively control. |
![]() Quote:
Cal-tracs ROCK!!! Click the link below to see his on the bumper run (pics). This is my buddies 68 Nova BBC, Vortech YSI Blow-thru! It runs consistent 1.28's 60ft. and a best of 1.25.
Jeff Kinsler's 68 Firebird (PY member) runs Cal-tracs and he runs 1.33-1.34 60 ft.'s http://gallery.godragracing.com/gall...ale_06?page=20 They work...period. You will have to spend sometime getting them tune-in, but when you do...hang on! Good Luck!
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
![]() Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) Last edited by bad69bird; 12-26-2006 at 02:45 PM. |
for sure, im glad i bought them now.
![]() Quote:
BTW, bad69bird what size drag radial is on that nova??? |
Pushrod,
They were 295's. We had our best 60ft. with the 275 DR (1.25) but they weren't consistent enough to keep on. There wasn't enough roll-out and the car kept over powering the tires.
![]() Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
![]() Quote:
He wants to try the 315's but we can't find anybody that has a set for us to borrow to test fit them. You should def. be happy with the 325's. BTW, how are you fitting them under your bird? Mini-tub?
Brian-
I tried 315's on my car- just the tires no rims. I placed them in the wheelwell and they hit the rear portion of the springs. My springs are moved 1.25". I need 1.75-2.0" total spring (rear of spring) relocation. THEN I think they will fit. John |
His frame rails are notched as well, but I don't know how much. Thanks for the info.
MrPushrod
How are you going to fit them under the Firebird ? What size DR do you think is the max on a stock suspension ? |
Also, who sells´em ?
No worries, found them
![]() Quote:
so............ I'll be able to fit almost any tire I want under the car. Building a 9" for the rear at the same time. I want the biggest drag radial I can get, the car will have coilovers/ladder bar and it'll be dumped on the ground. |
![]() Quote:
Unless you want the tires sticking out the sides.........but that looks like crap. You can also fit a 28x12.50 et street on that same wheel and it'll still look really good on a 1st gen car. I hate cars that have the wheels and tires sticking out. |
