Old 12-15-2022, 01:04 PM
Verdoro 68's Avatar
Originally Posted by Charlie Brengun View Post
That verdoro green looks fantastic in that picture you posted of your car! it looks really nice!
Appreciate it. It's a smidge off from what Verdoro should be (too much blue and too much flake) which kind of bugs me, but I get a lot of complements on it.
ID:	603622   Click image for larger version
ID:	603623   Click image for larger version
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 12-15-2022, 03:34 PM
NeighborsComplaint's Avatar
I have done most of the wrenching on my '71 GTO myself. The only exceptions were the rebuild of the trans and rear end gear swap. I've built installed 2 motors for it over the years, machine work of course was done by others. I stripped the underbody and undercoated it, installed all new suspension and steering components and did a 4 wheel disc conversion when I had access to lift. Paint and upholstery were done by others though I did install a dash cap the 4speed console modifying and automatic shifter to fit in it. I'm 70 now and just drive it and do minor stuff.
Triple Black 1971 GTO
Old 12-15-2022, 04:48 PM
taktikian taktikian is offline
Default Built not bought
It is awesome that so many of you can still do your own work. It is great to get it exactly the way you want it. Be great full and appreciative for what you are still able to do. I am jealous
Old 12-15-2022, 06:04 PM
Verdoro 68's Avatar
DIY projects over the years with the help of PY'ers...
A heartfelt thanks to everyone who has helped along the way. Thanks for sharing your knowledge, I couldn't have done it without you.
Ken
Old 12-15-2022, 07:03 PM
64speed's Avatar
64speed 64speed is offline
That was my goal when I started was to have a car EXACTLY how I wanted it. I have had lots of cars in my past but all were a compromise in some way. I have had all the 64 A body lineup. A Lemans, a GTO, and now the Tempest. I wanted to keep the Tempest too cause I wanted to be different. When the interior is buttoned up think the only remaining change I have is Pro Car buckets and a factory console with the vacuum gauge. Other than that I will be set...for a while. I can tell you guys one thing, if you want aftermarket gauges and are on the fence, spend the money on the Dakota Digital RTX. Yes they are twice as expensive but they are freaking AWESOME. I was on the fence about aftermarket gauges until I saw these in action. My block will be back from the machinist 2nd week of January and then I will start assembly. I am looking to have it on the road by March to go to the Run To The Sun but if not it will definitely be ready by summer.
Old 12-15-2022, 08:45 PM
tom s tom s is online now
Have done 4 cars in my garage and on my lift with everything except for paint and body.This was the one I was most proud of.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post:
Old 12-16-2022, 10:03 AM
HALFWAY's Avatar
HALFWAY HALFWAY is offline
I guess I fall into this category also.
Almost 5 years to restore in a 2 car garage. Luckily I had a full unfinished basement to store and spread out parts.
Wish I had found this site before I started. Would have saved me time, money and some do overs.
ID:	603651   Click image for larger version
I don't always cross thread the bolt - but when I do I run that bitch in with an impact until it's tight!
