Old 11-11-2023, 12:01 PM
78w72 78w72 is offline
Default 7/16 rocker studs for 6x heads?
Im going to be converting the rocker studs to 7/16 OEM BBC studs on a pair of 6x heads soon, can anyone confirm what BBC studs I need to do this? Are these just a certain year/vehicle I would order from any parts store like napa or summit, or are they something more special that needs to be aftermarket?
I see lots of options when doing a search for them, I dont think I need ARP or other expensive studs as this is just a mild cam at ~.480 lift in a street car, OEM BBC studs should be plenty strong. I may use poly locks but the factory crimped nuts should be OK too i would assume, the crimped nuts worked for 10's of thousands of miles on the cars that had them.
A part# would be great or just the years/vehicles that will work is fine and I can shop around for the best price on them. Thanks in advance for any info.
Old 11-11-2023, 12:54 PM
Formulas Formulas is offline
Paul Spots sells RAIV spec studs on Ebay very reasonable priced for trouble free use on your heads
And so does Butler
The Following User Says Thank You to Formulas For This Useful Post:
Old 11-11-2023, 03:51 PM
Thanks. Are RAIV studs the correct length for standard non RA heads like mid 70's 6x?
Ive seen the butler studs and some on ebay, Im OK with buying those if needed. Just wondering if there was an OEM option I could find locally at NAPA or oreilys etc to avoid paying shipping?
Old 11-11-2023, 05:41 PM
steve25 steve25 is offline
There the needed length to run ploy locks should you want to.
Old 11-11-2023, 06:40 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Standard BBC stuff from 1965 ish to the mid 80's, 396,402 427 454. Pioneer, Dorman or Melling will most likely be the cheapest.
Go fast, see Elvis!
The Following 3 Users Say Thank You to PAUL K For This Useful Post:
Old 11-11-2023, 07:29 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Some of the generic BBC studs the hex points stick up a little and can rub a big bodied roller rocker so I like the ARPs. The "regulars" are fine for stamped steel-and what HO used to sell with a thick hardened 7/16 washer to run under the nut.
Skip Fix
Old 11-11-2023, 08:46 PM
PunchT37's Avatar
PunchT37 PunchT37 is online now
Run the bbc stuff.
Old 11-12-2023, 07:22 AM
Kenth's Avatar
Kenth Kenth is offline
I´m using Pioneer S-1001 CBB studs with the crimped nuts set 1 turn preload on stamped steel original rockers.
No extra washer needed and the oil drip baffles under valve covers fits just fine.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-12-2023, 10:55 AM
Much appreciated! I will shop around locally for OEM BBC studs, do not need ARP in this engine with a very mild cam and stamped rockers.
Thanks again!
Old 11-12-2023, 11:44 AM
400 Lemans's Avatar
400 Lemans 400 Lemans is offline
https://www.ebay.com/itm/27612791640...QAAOSwll1WxeKc Paul Spotts has free shipping.
