Old 10-04-2016, 08:43 PM
ry57pont's Avatar
ry57pont ry57pont is offline
Default Power vs manual steering, ?
Has Anyone ever done a track test manual vs power steering? I'm thinking about going back to manual since I don't really drive it on the street anymore. Yup I know just one more step closer to becoming a race car.
1970 gto (4spd) 462 500 hp
11.940@114.21 / 1.843 60'/ 3980 lbs
1964 corvette roadster
1968 corvette roadster
1962 corvette
"equal rights, not equal things"
if you want to know the future, read "atlas shrugged"
I dont race a 4spd because it is easy, I race a 4spd because it is hard.
Old 10-04-2016, 10:43 PM
Way back when I 1st went manual I dont think I saw a difference I was at high 12 range back then. For me it was a plus not having something that leaked or an extra belt to worry about losing. A slower car (70 nova)lost a steering belt mid track(1/8 mile track) and I broke out by a very small amount but it wasnt my quickest pass of the day so hard to call. It felt quicker lol.
Old 10-05-2016, 02:05 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
In drag racing, "slower" steering is better and safer, so I would think manual steering would be better. Most drivers' natural reaction is to over-correct, when things get dodgy.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 10-05-2016, 07:25 AM
v869tr6's Avatar
v869tr6 v869tr6 is offline
I don't think you can put more than about 5 HP thru a single V belt.
Old 10-05-2016, 07:35 AM
JSPONT's Avatar
JSPONT JSPONT is offline
I use a newer S10 pick up manual box. It was a bolt in. I like it besides turning the wheel while the car is not moving.Once your rolling I like the feel better than the old power steering.
Old 10-05-2016, 10:23 AM
Doug Hopkins's Avatar
Doug Hopkins Doug Hopkins is offline
X2 Changing to a manual box is easy. Readily available, lots of rebuilt or new on Ebay. Agree with all the above posts.
Old 10-05-2016, 08:58 PM
Half-Inch Stud's Avatar
PS pump is "doing nearly no work" when wheels are kept straight.
I saw no diff for 12.0 ET & put the PS system back on, sold the manual box.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 10-06-2016, 01:07 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
So does yours have slack in the box once off center? Mine is tight on center but seems to get slack as you get more turns-about 4 locl to lock. Lares the remanufacturer of the S-10 I used(4 bolt cover) says that is normal for a manual box-but been awhile since I drove a manual.
Skip Fix
Old 10-06-2016, 07:35 AM
JSPONT's Avatar
No slack yet, it only has about 1200 miles on it. I like the tight feel of the manual while going a little above the speed limit.
