Old 02-07-2023, 07:18 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
Default fuel brake line clip(s) for 1971
Is anyone aware of a kit that contains all the drivers side fuel and brake clips for a 1971 convertible? Some of the locations are shared some are the drop tab kind some are not. Maybe 6 clips or so total on the side.
I ordered the stainless replacement lines and the diameter of the lines with the springs seems a little larger than what came out. nothing fits quite right, which is why i ordered the premade stuff vs just throwing nicop lines in. i need to measure, but between the lines not quite following the old bends and the body being on, this is a PIA for sure, so id like to make it as done as possible with the correct style clips.
the inline tube offerings don't look the same as what came off.
thanks in advance
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 02-09-2023, 02:02 PM
tjs72lemans tjs72lemans is offline
If it's anything like some of the short brake lines to brake master cylinder I got from them, they need rebending to fit.
