Died
Took a look at the distributor tonight - all the wires look good and nothing is loose or out of place. I also rotated the engine over by hand to put my mind at ease. I wanted to make sure there was no interference or odd sounds. I doubled checked the position of the rotor to the cap and the timing looks to be where I left it.
There's an original Pertronix in there now, so I'm thinking that it's probably the culprit. I went ahead and ordered up a new cap, rotor, coil and a Pertronix II unit to cover my bases. We'll see if those will get this thing fired back up. Pulling the distributor will also give me another opportunity to prime the engine before I try to fire it again.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
Ken, might want to throw a set of points in just to get it running. I remember my car shut off during break-in. I restarted in 10 min after I check different things but mine did restart right away.Any oil pressure issue's? BTW just curious what cam are you using?
'68 GTO '69 Corvette '75 Cadillac Coupe Deville TOM |
Pulled the distributor and tested the Pertronix today. It seemed to still be working according to the multimeter, but I replaced it anyway with an Ignitor II.
Put in a new cap, rotor and coil and it immediately fired up and I was able to finish running in the cam My bet is it was a bad coil. Got a couple leaks to address and of course retuning, but it looks like the worst may be over.
Good bet. Dam things.
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
Distributor was tight and didnt turn on you, happened to my first GTO back in 1986, just died while driving and would crank but not start. Turned out the distributor hold down loosened up and it turned.
Good deal.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
sometimes there nothing better than just a stock hei unit....
1970 firebird, 468, e heads, |
Didn't test the old coil, but it's still sitting on my bench. I'll take a look at it when I get a minute if only out of curiosity.
The engine sounds good and there's no signs of backfiring or missing so I think it broke in just fine. I still have to change the break in oil, hopefully I won't find any glitter in there.
Pertronix units seem to take out coils after a while( about two years of to and from work driving), Had it happen to me twice.
The coils start to run real hot and then short out. The first time it happend I had the coil still on the motor and could not tell it was overly hot. The second time It was on the fire wall and when the motor started to drop spark and run poor the coil would near burn your hand to the touch.
