Old 09-16-2023, 04:10 PM
grivera's Avatar
grivera grivera is online now
Default 8.2 Rear with UT axle code
I picked up a 1967 8.2 Posi Rear with what appear to be nice 3.23 gears. The axle code is UT or UI on left tube/rear- and I can’t find any info on it. This one has the provisions for the upper trailing arms on the center section and leaf spring perches welded in at Firebird width. Backing plate to backing plate is ~54.25”
I read somewhere the 67 Firebird rears may have come with the loops for the trailing arm bushings, and other brackets at bottom of tubes- is that the case here or is it a frankestine?
ID:	620090   Click image for larger version
ID:	620091   Click image for larger version
ID:	620092   Click image for larger version
ID:	620094   Click image for larger version
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 09-16-2023, 05:12 PM
It's a 3.23 gear (UT) with locking unit for a Firebird, so it would have the stuff for the leaf spring bars.
Old 09-16-2023, 05:24 PM
grivera's Avatar
Gotcha- thanks. Does the posi unit look like factory style?
Will Rivera
Old 09-16-2023, 08:50 PM
turbo69bird's Avatar
Is it a nodular ? Have the N cast into the top?
I thought all Nodular’s had a Julian date code?
960 HP @ 11 psi, 9.70 at 146.
Old 09-16-2023, 09:12 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
It's a 2 pinion Saf-T-Track unit.
Center section would be casting number 9783393, grey iron. ol' Pinion head posted good info here...
https://www.gtoforum.com/threads/rea...ission.124546/
So long, farewell.
Old 09-16-2023, 10:42 PM
grivera's Avatar
That’s a great read - thanks
Will Rivera
Old 09-17-2023, 08:50 AM
grivera's Avatar
I suppose pretty good chance the cones are worn?
Will Rivera
