Old 09-10-2023, 10:57 AM
grivera's Avatar
grivera grivera is online now
You are a wealth of knowledge- thanks for helping piece the puzzle together!
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 09-11-2023, 11:46 AM
grivera's Avatar
PHS is redoing the window sticker to correct the cost of the transmission and the power steering.
Will Rivera
Old 09-11-2023, 12:56 PM
If they are fixing it you should get them to also correct the trim code, it should say 57 rather than 25.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 09-12-2023, 05:35 PM
grivera's Avatar
Yup, PV is 350 2bbl with AC, PS is the code for 350 HO. Application.
Since this one has no AC, assume they just left the tag on trans for an AC application?
Is that the same as the "TR 257" on the trim tag (Post 1)? https://forums.maxperformanceinc.com...96&postcount=1
Will Rivera
Old 09-12-2023, 05:44 PM
Yes but I’ve noticed on original Baltimore window stickers they only print the last two digits.
Window stickers varied, in terms of how they were filled out, from one plant to another.
1969 Bonnie Cvt
Old 09-12-2023, 05:55 PM
Don't know the LeMans codes, but usually the cowl tag code - 257 is code 571. they drop the one and put a 2 in front of what is left - 57.
(for a Firebird )
Old 09-12-2023, 06:29 PM
The code for parchment buckets is 257, same code for LeMans and GTO). The first digit (2) is used on all F, A and G bodies (the B body interior codes all start with (5)).
Code 571 has nothing to do with interior codes, 571 is the code for headrests which were a mandatory option on all 69 Pontiac’s until Jan 1st when they were made standard equipment.
Here is a pic of the relevant page of the trim booklet that year…
1969 Bonnie Cvt
Old 09-14-2023, 08:17 AM
grivera's Avatar
I had them correct the engine code on the memo as well - it’s an XS block vs the YU listed.
Will Rivera
