8.2 Rear with UT axle code
I picked up a 1967 8.2 Posi Rear with what appear to be nice 3.23 gears. The axle code is UT or UI on left tube/rear- and I can’t find any info on it. This one has the provisions for the upper trailing arms on the center section and leaf spring perches welded in at Firebird width. Backing plate to backing plate is ~54.25”
I read somewhere the 67 Firebird rears may have come with the loops for the trailing arm bushings, and other brackets at bottom of tubes- is that the case here or is it a frankestine?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project Last edited by grivera; 09-16-2023 at 04:29 PM. |
It's a 3.23 gear (UT) with locking unit for a Firebird, so it would have the stuff for the leaf spring bars.
Gotcha- thanks. Does the posi unit look like factory style?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
Is it a nodular ? Have the N cast into the top?
I thought all Nodular’s had a Julian date code?
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
It's a 2 pinion Saf-T-Track unit. Center section would be casting number 9783393, grey iron. ol' Pinion head posted good info here... https://www.gtoforum.com/threads/rea...ission.124546/
So long, farewell. |
I suppose pretty good chance the cones are worn?
