Old 05-07-2023, 10:48 PM
grivera's Avatar
grivera grivera is online now
Default Looking at 1984 Mercedes 380 SL Roadster
May be looking at one this week. Owner says 138k miles, ran fine in 2018 when parked but now running crappy with the old fuel. Anything to look out for with these cars? Pitfalls, etc?
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 05-08-2023, 02:36 AM
SRR's Avatar
SRR SRR is offline
Walk away...money pit!
― Calvin Coolidge
Old 05-08-2023, 03:58 AM
Lightfoot's Avatar
This YouTube channel is a decent place to get some tips on high end foreign cars and what to expect when owning them.
He doesn't go back as far as 1984 in this video, but I have heard him warn that certain cars are way more costly to keep serviced than they are worth.
https://youtu.be/JDJQa0VGMho?t=60
A couple more videos that may be more insightful:
https://www.youtube.com/watch?v=AGKa6QqGKbU
https://www.youtube.com/watch?v=PaW_ALQ7ZZo
Old 05-08-2023, 07:45 AM
400 4spd.'s Avatar
That engine is known for timing chain problems, as they were a single row design. Usually noted by extreme rattle on start up. The fix is a double row chain and gears, requiring engine removal! Injectors, elec. fuel pumps and relays are other common failure points.
Floor pan rust is another concern, due to firewall leaks and around the folding top cover. Look under the jump seat if it has one. If A/C is shot, forget about getting some of the parts it might need, especially servos.
With that said, I'm restoring a 1982 380 for a customer, so that's why I am familiar with some of the issues they had.
Old 05-08-2023, 08:22 AM
grivera's Avatar
Thanks for the pointers. I saw in a video that the 1984 is the first year for the double timing chain.
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 05-08-2023, 09:22 AM
400 4spd.'s Avatar
I have a 1984 280SL (OHC 6) that I am pulling parts from. If you get the 380 and need parts, I might have something you can use.
The Following User Says Thank You to 400 4spd. For This Useful Post:
