Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 10-27-2020, 06:18 AM
duke455's Avatar
duke455 duke455 is offline
Default Shaft rockers
Any good used shaft rockers for sale for standard location Edelbrok heads...thanks
Old 10-29-2020, 05:45 PM
duke455's Avatar
Gotta be something
Old 10-29-2020, 08:01 PM
Do yourself a favor and buy a new set
Old 10-29-2020, 08:07 PM
duke455's Avatar
More then likely I will..just thought I'd see if there was anything out there..
Old 10-31-2020, 04:56 PM
gogtogo's Avatar
gogtogo gogtogo is offline
My Crower SS shaft rockers for my KRE HP’s should up Wednesday. Took about 3 weeks and worth every minute and cent!
The Following User Says Thank You to gogtogo For This Useful Post:
Old 11-01-2020, 03:26 AM
Check with paul k on here. He may be able to help you
Old 11-01-2020, 08:54 AM
AIR RAM AIR RAM is offline
Does anyone know if all shaft rockers systems need tweaking to install or are there any "bolt on" shaft rockers available? I cant seem to make heads or tails when shopping around. I have 72cc RPM E-heads and I have read that the TD shaft system may need machine shop time in order to make them work correctly...
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
