With the small changes in CR do you understand how few cc's difference is being talk about?
Stan
Stan,now go back and put in 4.21 stroke,also maybe 30 over if block is worn.He said he was going to use a 455 crank.Tom
Tom,
If I do that and increase the head gasket bore +30 I would need a 101 cc chamber to start at the same CR as the above graph. Stan
A question for OP.
Are you using 455 pistons along with the 455 crank? The 428 pistons will be wrong on the 455 crank.
John,I think he is talking custom pistons!Tom
I figured that. But maybe trying to use 428 custom pistons?
The pin height is different from a 428 piston and a 455 piston whether domed or not.
Thanks johnta1. I hadn’t ironed that out yet but I have now.
i have a ?
I thought compressed head gaskets were typically .039" not .030 |
This is a custom gasket. Not a stock gasket.
