Old 08-15-2021, 07:32 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Default E-85 total/locked out timing on KRE D-ports?
Is anybody else here running E-85 on a KRE D-port engine? If so, what is your total timing? I went racing this past Friday and set the timing at 33 degrees (locked) and the car started sputtering. I backed it off to 31 degrees but didn't get another run in due to a no headlight issue (oops).
Attached is the time slip, I'm P488 right lane. I really thought it I was finally going to get it in the 11's on motor until the sputtering issues around 4700 rpms.
Another E-85 question, should I run a hotter or colder plug for the fuel? I'm currently running NGK R5671A-7 plugs just like I was with race gas and nitrous.
Thank you,
John
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 08-15-2021, 10:21 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Good plug for E85 even with big compression - 13 to 1
The Following User Says Thank You to CraigG. For This Useful Post:
Old 08-15-2021, 11:07 PM
quick67bird's Avatar
quick67bird quick67bird is offline
No time slip attached Johnny.
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 08-15-2021, 11:08 PM
Johnny406's Avatar
Oops, the time slip didn't post the first time...
Name:	time slip 12.249.jpg
Old 08-16-2021, 04:41 AM
charlie66's Avatar
Been using e85 now since 2010 and ive tried from 7's all the way to 11's and now im back to an 8. The cooler ones seem to wear out fast for me . Tried 7's and they just never seemed right at the strap. So 8 it is now.
Id call Jeff about the timing question..
My Half AN Injun.....
Old 08-16-2021, 06:07 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Sputtering sounds like fuel or ignition delivery. Not timing.
Old 08-16-2021, 06:50 AM
mysticmissle's Avatar
we run 7s in our e85 combos, i think my buddy Jake with his kre dports is in the 31 degree range. I think he needs more timing but he is super cautious. about 13:1 406 w small hydraulic roller
how does your fuel test? a really good batch (E90) may cause issues if youre set up for a mediocre batch. (E70)
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 08-16-2021, 11:21 AM
Scott65's Avatar
Scott65 Scott65 is offline
E85 should like a few degree more timing than gasoline, not less. You have accounted for needing approximately 30% more fuel delivery hopefully?
Old 08-16-2021, 01:23 PM
Johnny406's Avatar
I really thought I did but after reading JSchmitz and your post, I'm now not so sure. I'm running 1/2" line from the sumped cell to the carb. I'm using a Aeromotive SS pump mounted below the fuel call, a PRO-Systems E85 compliant return regulator and a fuel log. I did order a new 100 micron stainless steel filter for the pre-filter. I currently have a 35 micron filter before the pump and an identical one before the regulator (pictured). I just cleaned them both Friday afternoon.
Old 08-16-2021, 01:30 PM
JSchmitz's Avatar
Do a free flow test into a container and check rate. Best if you can see or data log pressure during a pass. When I added an interior pressure gauge, it was an eye opener. Even when the engine isn't cutting out yet, your pressure can drop and lean the car out.
Old 08-16-2021, 02:30 PM
Scott65's Avatar
Ditto the flow test. I had an issue with a brand new pump not putting out the volume it should have. Pressure looked good, but the volume wasn't there. Flow test found it. The way you describe it laying down, fuel delivery does come to mind.
Thread Tools
Display Modes
