#41
Old 05-22-2021, 10:41 AM
Originally Posted by ta man View Post
I installed the Doug's Headers today to replace my old Hooker Super Comps. I had to clearance the driver's side control arm and slightly flatten a passenger side tube that was resting on the crossmember. I wasn't too pleased with that. I think the issue is the header mounting flange is too thick. If they made it thinner all the clearance issues would go away.
The middle bolt holes were easier to get at on the Doug's as well as a couple other holes compared to the Hookers.
But overall the Hookers actually fit and go on easier with any modifications..so a heads up to anyone making a choice.
I've had the same experiences. For some reason the Dougs always come recommended and I could never figure out why. I've had to modify every set I've ever tried, and it is a little disheartening after you spend the extra coin on the coating.
The Hooker Super Comps have always dropped right in for me. I've even experienced this on Chevrolets.
https://youtu.be/XqEydRRRwqE
  #42
Old 05-22-2021, 11:59 AM
ta man ta man is offline
Originally Posted by 78w72 View Post
round port or D port headers? & what size tubes for the hookers & dougs? i use the 2" O-port super comps on a 2nd gen that fit & install surprisingly well but hang a little to low for how low the car is.
what do the taller front tires benefit, just the stance or less rolling resistance that ive heard people say? i just changed my 26" fronts for a set of sportsman 28 that are closer to 27.5 to help get the nose up that sat too low.
D port headers. When I bought the 26's M/T didn't sell a 27 inch S/R so I went with the shorter tire. The 27 will fill the fender better and level the car out a little more.
  #43
Old 05-22-2021, 12:00 PM
I've had as good luck with my Hookers as anything. Yes esp #5 bolt is a pain! With my RAIV 400 I needed smaller size 1 3/4 and the Hedman's would not even bolt up. Cut off 2 tubes and redid and easy bolt access!
  #44
Old 05-23-2021, 10:27 AM
Getting closer to a road test, fitted, tacked and welded the front exhaust section. Now I just need to tweak my tailpipes.and also clearance for the drivers side header again!
Sent from my BBF100-2 using Tapatalk
The Following User Says Thank You to ta man For This Useful Post:
  #45
Old 05-23-2021, 11:44 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
A taller tire will move the car back on the starting line and slow the RT. I tried running 26” front tires and had red light issues with an off idle launch no matter how deep I’d stage. 27” tires and running air pressure down to 25psi to make the tire “act” taller and RT’s are usually .01-.03 off the foot brake.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
  #46
Old 05-23-2021, 12:51 PM
78w72 78w72 is offline
thanks for the info, good point about RTs. however i dont care much about RT's right now just doing test & tunes to work out bugs & see what the car will do... you can sit at the line for 30 seconds if you want & wont affect the ET's.
i have read/heard that a taller tire reduces rolling resistance though, not sure how much that will help et's or 60ft but it makes sense. i think taman meant the taller tire will help get the nose up more.
  #47
Old 05-23-2021, 01:03 PM
Something not mentioned, a taller tire also increases roll out. In other words the car moves forward more before it trips the beam and starts the timer. The car will run a slightly quicker ET with a taller front tire as a result, if you're careful how you stage the car (not too deep)
  #48
Old 05-30-2021, 11:33 AM
I finally had the car out for a test drive yesterday. Car feels lighter and more responsive. I notice the higher rpms down the highway, but the engine feels pretty happy at 2700/2800 rpm. The ProSystems carb is now able to quickly go to full throttle and has instant throttle response from a standstill. Thanks to a good local carb guy for advice and of course Tom Vaught as well.
I'm pretty happy with the stance of the car now as it sits almost level.
  #49
Old 06-22-2021, 10:53 PM
Originally Posted by promptcritical View Post
How do those Calvert split monos ride on the street? Maybe you haven’t driven it yet.
Have a few miles on them. feels the same. The car sits about one inch lower in the rear(it used to sit about one /one half inch above stock ride height. With the adjustable shocks I have them at 5 out of 9 for firmness. So I could actually soften the ride up if I wanted to.
  #50
Old 06-23-2021, 07:56 AM
Last two sets of dougs I had were on the disappointing side, both needed work, and the one a body set the driver collector was cocked to one side. I will probably go back to Hookers.
  #51
Old 06-23-2021, 09:05 AM
77 TRASHCAN's Avatar
Looking forward to some 1/4 mile passes, to see, "What's up".
It seems crazy that it's almost July. June 20 was the summer solstice day, most daylight of the year. Now we are going the other way. It will be a while before the difference is noticeable...
Shut it off
Shut it off
  #52
Old 06-23-2021, 09:37 AM
I was hoping for this weekend but the weather doesn't look good so far. Yes time goes by quickly. Our tracks have had a slow opening this year due to the Pandemic...and as always the weather never seems to co-operate.
I'm really itching to get out and test..I should have had the carb figured out last year but ran out of time last year. I believe last year if I had the carb issues figured out..it would have ran at least half a tenth quicker then its best et..maybe a tenth quicker...the mph was higher even with the carb issues.. So that will have to be taken into consideration this year if I knock a few tenths off the best et. I will have to run the carbs back to back one day this year. I know Andy and I have talked about running his big carb as well on my engine on a test day...so a 3 carb shootout may be in the works. So that would be a 950 HP Holley vs a Pro Systems 1000HP/Venom vs a Shaker prepped 1000HP Holley?
  #53
Old 09-15-2021, 06:11 AM
I just realized I haven't made any updates for a while. I've been to the track twice this year. The first time Andy and I went the track was a zoo and being a street car night the track quickly disappeared. Plus quite a few oil downs and breakages on the track I was limited to 2 runs. Best one was a 11.04/125.42 with a 1.6389 60ft with a slight spin. This day I had the Prosystems carb on.
Last Friday went to TMP..track prep held for a few runs..but with a 11.1 and a 11.01 with 60's in the 1.60 to 1.62 range I was a little disappointed. This time I had the 950HP Holley back on.
So if anyone who has followed this thread knows ,I've been fighting a 60 foot issue for a while. Its a combination of limited track times and also I believe blaming the wrong part. Looking at all my timeslips I haven't ran an under 1.6 60 foot in three years. Last time was before I swapped convertors and then swapped quickly back to the Continental convertor becuz of the high slippage in drive with the UCC .
Friday night I realized its most likely something up with the transmission causing the slow 60 foots..first and reverse do feel a little draggy. I'm thinking the transmission was hurt 2 years ago with the higher stall of the UCC convertor. This week I'm in the process of swapping in a back up transmission to test my theory.
So to make a long story short..the best 60 foot so far with 3.73 gears with a 2.75 low gear set has been 1.60 vs a 1.54 with 3.08 gears with a 2.75 low gear set. This is the issue. Last year the car would 60 foot in the 1.61 to 1.64 range with the 308's.
Hopefully Sunday I can make it to a track day to test. I still fully expect to see 10.5 out of this combo with 60 foots in the 1.50 range or slightly lower eventually. The replacement transmission has the stock first gear set so if it 60's well it will confirm damage to the transmission.
  #54
Old 09-15-2021, 07:51 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Thanks for the update.if it was easy everyone would be doing it. Good luck!
Go fast, see Elvis!
  #55
Old 09-15-2021, 08:00 AM
You got that right! My niece was at the dragstrip Friday night and was explaining to her boyfriend who has never seen the car that 11.01 is slow for the car. Even after I put bus lengths on a 2021 Vette.
The Following 3 Users Say Thank You to ta man For This Useful Post:
  #56
Old 09-15-2021, 05:28 PM
TCSGTO's Avatar
The only time everything works perfectly out of the box is on TV shows and Dyno sims. It takes determination, drive and hard work to get a combo where it should be and he’s got that covered.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
The Following User Says Thank You to TCSGTO For This Useful Post:
  #57
Old 09-18-2021, 11:56 AM
Well it turned out the replacement transmission didn't work out well, it had a sloppy 2 3 shift and wouldnt hold drive.
The good thing is it actually felt better in first gear, so old transmission is going for a refresh/rebuild hopefully back together soon and running.
Goal is still 10.5 this year with a 1.5 60 ft..best is 10.76/1.54
  #58
Old 09-18-2021, 01:02 PM
PAUL K's Avatar
See post#54
Good luck and thanks for the update.
Go fast, see Elvis!
  #59
Old 09-18-2021, 04:12 PM
ponjohn's Avatar
ponjohn ponjohn is offline
With the 2.75 first gear and the 3.73, is it shifting out of first before the 60ft?
  #60
Old 09-18-2021, 07:37 PM
Shouldn't even be close.
That's only a 10.25 effective ratio. You'll need more than that to make 1st gear shorter than 60 feet.
I'm running one car with a 2.95 and 3.73's and a short 25.6" tire and it's still pretty far beyond the 60 before I snatch second, at least 30 feet past the box, and I'm only shifting that one at 5500.
Pretty sure he's running a taller tire than that too.
