Old 01-04-2021, 02:36 AM
Vid's Avatar
Vid Vid is offline
Default Motor mount question, '77 block in '69 A Body
Hi all,
I need to go to school again... someone please refresh my memory about the correct mounts to get a '77 400 block to drop in correctly in my '69 LeMans (which currently has a 350).
It recall I went through this "the hard way" when I swapped a '78 400 in my '67 Tempest wagon and the whole motor was moved back 3" or 4" which turned into a major PITA with driveline, linkages, exhaust etc. Sure would like to avoid that headache this time around if I decide to go this route. I'm sure there must be an "easy way".
Thanks in advance
Old 01-04-2021, 02:56 AM
Stuart's Avatar
Stuart Stuart is offline
Butler Performance sells motor mount adapters for your application: https://butlerperformance.com/i-2445...tegory:1393557
Old 01-04-2021, 12:49 PM
Vid's Avatar
Vid Vid is offline
Boom! Thank you Stuart!
Old 01-04-2021, 05:59 PM
JSPONT's Avatar
JSPONT JSPONT is offline
I have a set lmk if you are interested. 25.00+ shipping. Think they are painted metallic blue
