#61
the only produced V header I know of at this time is gen 1s from Nunzi.They are 4 tube and fit very well.Tom
#62
RAV INTAKE
I'm with Mr. GTO on the availability of an EFI version of the manifold. I would like to see one that flows more than the Torker II, and fits under the hood. Great looking stuff. Congratulations.
1973 Pontiac Grand Am ERL built 430 CI LS7, Brodix STS BR7 heads, Magnum T-56 6-speed, Modulare 19" wheels, QA1/Global West/Speedtech suspension, Wilwood 6/4 piston brakes. BMW Donnington Gray paint. All wrapped up in a Hurst Pontiac tribute theme. |
#63
Yeah - they fit very well after you pay someone to fix them...
#64
I can probably do some give me some time to look on my old computer to see if I still have the Ram Air file. |
#65
Well should say MINE fit well WITHOUT paying anyone to fix them.Tom
#66
Maddog headers shows a RAV header in his catalogue.
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
#67
They make the Nunzis.Tom
#68
Sorry, Polar-P. We do not yet have the race flow numbers. This involves Tony Bischoff to finish porting.
We put our head on an uncalibrated flow bench with zero clean up and a surface cut, but no good valve job. The prelim test and it was almost 360 cfm@600 as cast compared to the stock head at 312. This is with a 25 to 30% smaller cross sectional area. We have had Tony do some final touches and put a good seat for final numbers to be changed in the tooling. I will publish the final numbers on RamAirV.com. We are extremely optimistic about the ported stuff making serious Pontiac power. Lynn |
#69
Gen Firebird. We will be testing them on the 480 cu inch street crate motor for best sizes for the street. Lynn lmc3470@aol.com |
#70
Good Luck finding 4 tube RAV headers.
#71
Lynn, what does Tony think about the pushrod tube and it possible causing issues with the air/fuel? Are these heads offered with the foil design pushrod tube or just the tube?
#72
Lynn |
#74
We already have them set up for production. Tri-Y or regular. Later we are going to make stainless steel (needs special dies). We have 64-72 GTO, 67-73 Firebird with more to come. We are also working on a mock up system for custom headers. We are going to the dyno to determine the best streetable header for a RA-V.
Lynn |
#75
#76
Cool, thanks. |
#77
hummm...ebay and craigslist here I come. It is now time to find a 69 Firebird body. A pure stock appearing Ram Air V 69 Firebird would be the ultimate in my mind. Dog dishes and all.
RARE needs to make factory style exhaust manifolds for us original type guys...
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. 1966 GTO Hardtop - PS 14.84 @ 97mph |
#78
Here's the new body from Dynacorn, pricey..... but new:
http://www.justsheetmetal.com/classic_body_FB69.asp |
#79
Lynn |
#80
Lynn McCarty lmc3470@aol.com Last edited by NHRASuperStock455SD; 03-26-2010 at 02:16 PM. |
