Old 02-12-2014, 12:21 PM
Ray Cox's Avatar
Ray Cox Ray Cox is offline
Default Front coil over conversion info. Tip
Someone may have already figured this out but I couldn't find any info on it. So I figured I would share. Might work on 1 st gen also not sure.
afco makes 2 conversion parts to bolt an afco coil over into the factory control arms on a 2 nd gen Ta. I had thought qa1 was the only bolt in.
The bottom is a direct fit however I think some reinforcing will be needed on the lower arm where it bolts in just to be safe. See the pic below.
The top is also a direct fit no drilling or changes. The pic below shows the adapter but I don't have the rubber grommets yet. Also they say to use washers for the snap ring wich I don't like so I am making an aluminum ring with a snap ring grove like the rod end has. I will post a pic when it is done
Basically this kit would convert any set of coil overs to bolt right in to a 2nd gen car with no mods to the car or arms.
I know it's not a big deal with tubular arms, but some classes don't allow frame mods or tubular arms. Not to mention they are $1.000.00. And have no performance advantage except a weight loss.
This afco conversion vs my springs and shocks will save me about 18 lbs total. Plus the performance advantage. The upper control arm factory is 7lbs 2 oz the tubular is 4lbs 4oz so not much savings in weight and nothing in performance. The lower control arm is 15 lbs 3 oz factory and 9 lbs tubular so very minimal weight loss for a 1 k item.
8.30 @ 165 mph 3,380 LBS
The Following 2 Users Say Thank You to Ray Cox For This Useful Post:
Old 02-12-2014, 12:23 PM
Ray Cox's Avatar
Top mount
The Following User Says Thank You to Ray Cox For This Useful Post:
Old 02-12-2014, 12:24 PM
Ray Cox's Avatar
There are a few other little tricks and mods to it I will take some pics as I get them done.
Old 02-12-2014, 06:39 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
A lot of people have found that there is not enough stored energy compared to a coil spring and the car will work better with a coil spring then the coil over.
First Pontiac powered street car in the 7's
7.940@170.84. 3460#s
The Following User Says Thank You to LiL Jack For This Useful Post:
Old 02-12-2014, 11:45 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Default 1st Gen - stock bottom CA's
Not mine, but I did the same idea.
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 02-13-2014, 09:31 AM
Ray Cox's Avatar
That's interesting.
Old 02-13-2014, 10:15 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Im changing over from the qa1 coil over sping to a conventional Santhuff spring right now. you need a really good shock to control it though.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046 jet
First ultra street/ultimate street NOS car to get into the 4's!
1.079 4.559 153.23.
3100 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
T2TTFMF!
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 02-13-2014, 10:19 AM
Ray Cox's Avatar
I am trying to get in touch with roades to get his help but I think he is too busy. I have Afco's for it. I don't really have a ballerina budget like little jack for the santhuff shocks but I could probably do santuff springs. Dwight said he is doing that also.
Old 09-21-2014, 10:17 AM
bankbook's Avatar
bankbook bankbook is offline
How did you make out?
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 09-21-2014, 07:57 PM
Vengeance Race Engines's Avatar
Vengeance Race Engines Vengeance Race Engines is offline
This^^^^ x2
I have been saying that for a long time and not just because of the stored energy thing. front coil overs, to me, are very application specific. The only thing I actually like with them is the simplicity of ride height adjustments in the front, but agree they are not the best way to go in most setups.
Old 09-21-2014, 10:03 PM
Ray Cox's Avatar
I ended up going a different route havent had a chance to put these up for sale yet but i wont need them.
Old 09-22-2014, 05:54 PM
taff2's Avatar
taff2 taff2 is offline
Coilovers should work fine on the front if the shocks are long enough. I find most coilovers are too short and the springs you have to use to stop them bottoming out don't have enough stored energy/travel.
