TIMING CHAIN
Does anybody make a .030 shorter chain?
Your car must be very fast ! Because you were haulin ass when I passed you in my GTO. |
What would lead to needing a chain that short?
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
Align boring that leads to crank being .015 closer to cam?
Correct!
Jez, .030"!
I would look into adding a small tensioner. Actually I would be looking into this even if my motor did not need a shorter chain!
Cloyes does make short timing sets. They typically stock -.005, -.010 -.015 can be had by special order. Possibly Rollmaster has short sets as well. Typically, there may be .001"-.002", variation in the chain itself. The "short" set actually comes from machining the sprockets to carry the chain a tiny bit higher. Are you sure you need a -.030" timing set? I have line honed many Pontiac blocks, some race applications as many as 10 times. Typically a Pontiac block that has been line honed 10 times is still nice and tight with a -.010" timing set. How loose is a standard set when installed?
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
Wow. If the center to center distance has really changed that much, he may have to go to some type of tensioner.
Son-in-law's block ended up .022" removed to clean things up. We looked around and never found a timing chain set that would work. He will be going with a gear drive that he has purchased but not installed yet.
If needed, I recommend the Milodon single idler gear drive which I have used for years on my engine after getting tired of slacked out rollmasters.
Easy to degree in the cam, makes no noticeable noise that I can tell and has rock solid timing. Install isn't bad with engine on stand but surely could be done in car I think and is set to the individual engine regardless of line hone tolerances. My experience, yours may vary |
Trial and error ? I have not put the crank in the block yet, maybe this weekend so I can got some sort of idea. I believe Spotts sells .003 shorter chains, might start there. But it can get expensive if its still too lose. I don't expect to need a real short chain as Dan was a perfectionist and had a boring bar like the Berco or one like it. |
'65 Tempest 467 3650# 11.30@120.31 |
anyone have any thoughts on this?
Does your builder have an opinion on the situation? Seems like a gear drive may be your only real option at this point. A BOP belt drive would do the job but hardly appropriate in a street build in the street section. I am a little perplexed as to why they would have machined the mains that much without a plan? But I guess a gear drive would get you out of trouble.
We have had this running already with a .010 chain, it was still a little loose but it ran great and I never had any issue with the timing. Just thought while we are in here again we should try and address the problem properly.
Could you measure from top of cam journal, to bottom of crank, then subtract 1/2 cam journal diameter and 1/2 crank diameter?
I had a similar issue with a late model engine I freshened. I used what was called Cam Correct. I don't know if is still around, but it consisted of a jig and a tensioner foot along with the spring. I still have the jig and have used it on newer builds. My engines were always fast and reliable. I suspect it could be fitted to a Pontiac with some adjustments because of the machined block front.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
