Old 10-29-2014, 06:37 PM
ultraman's Avatar
ultraman ultraman is offline
Default rear brake problem
i am restoring a 79 4wheel disc brake ta the brakes will not bleed and the parking brake does not work any help would be great.
Old 10-30-2014, 05:49 AM
68ragtop's Avatar
68ragtop 68ragtop is offline
Did you replace the master cylinder? If so, did you bench bleed all the air out of it before installing? Could be just too much air, or maybe the bleeders are plugged up? I like using a vacuum to pull out the fluid, but gravity bleeding usually works too. What parts have you replaced?
http://www.mityvac.com/hq_images/MV8000.jpg
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 10-30-2014, 07:35 AM
ultraman's Avatar
I put a new master cyl and 2 new front calipers because i broke the bleeders off.im not getting any fluid even with the rear bleeders removed.thefront bled out normally.The parking brake looks to have full travel.thanks
Old 10-30-2014, 08:35 AM
kevin.1 kevin.1 is offline
I had the same problem on a 69 Firebird & 69 GTO (nothing coming out of rear bleeders). Both were the same issue... rear brake hose was plugged. Never thought that could happen, but seems they fall apart inside and plug up the passage.
Quick check is to simply loosen the brake line where it connects to the rear hose then gently press the brake pedal.... fluid should shoot out of that loose connection (wrap a rag around it to avoid fluid spraying all over the undercarriage).
Good Luck!
Kevin
Old 10-30-2014, 06:09 PM
77 TRASHCAN's Avatar
I went through some goofy contortions w/ my brothers 73 camaro.
Converted it to 4 wheel disc, (front stock, aftermarket rear). Had to use a vacuum pump w/ one of those bleeder cups to get fluid to the back.
Don't know the real problem...replaced the m/cyl that came w/ the kit, it solved all problems...
Shut it off
Shut it off
Old 10-30-2014, 08:32 PM
bs78ta's Avatar
bs78ta bs78ta is offline
I am going with ragtop on part of this. The question was not answered Did you properly bleed the M/C before installing.
Butch
Old 10-30-2014, 09:10 PM
2manyT/A'S's Avatar
The rear calipers are or can be a problem on those years......
The pistons have a ratchet mechanism in them which is activated when the parking brake is applied.....
If you don't use the parking brake,the rear brakes become inoperative....
You need to check that both rear pistons are adusted out enough for pads to contact rotors.
Eye Candy......garage band?
Go full screen & turn it UP!
Old 10-31-2014, 07:31 AM
ultraman's Avatar
Yes i bled the master cyl front and rear ive found the fluid going into propotioning valve nothing coming out.this car has been sitting up off road for a long time.can i use a valve off a disc drum car?
Old 10-31-2014, 10:44 AM
No....!
Shut it off
Shut it off
Old 10-31-2014, 04:26 PM
bs78ta's Avatar
Not if you want to stop . Must be a 4 wheel disc prop valve.
Butch
Old 10-31-2014, 05:21 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Or just T the fronts and do an adjustable in the rear line.
Couble check the rear calipers also besides the line. the ratchet locks up frequently.
Skip Fix
Old 10-31-2014, 05:34 PM
68ragtop's Avatar
Is it possible that the prop valve piston slid so far to the rear its its blocking the rear passageways? I have never taken one apart, so I am not sure how far it can move.
Just a thought.
89 Trans am GTA
Old 10-31-2014, 06:28 PM
ultraman's Avatar
That sound spossible Iremoved the end cap and the piston was toward the rear outlet fully.I might try to tap the piston in.thanks.
Old 10-31-2014, 06:49 PM
68ragtop's Avatar
Is the brake light on? it should be on anytime the pressures get unequal & the piston gets pushed one direction or the other.
89 Trans am GTA
Old 10-31-2014, 08:11 PM
ultraman's Avatar
I have the front clip off right now toput the engine and transmission in.almost to the point of hooking up power.just going from one bug to another.previous owner removed everything with a bolt most parts lost in trading hands.ive got it heading in my direction now.
Old 10-31-2014, 08:40 PM
68ragtop's Avatar
you could check it with a multi meter. The electrical connector on the valve should have no connection when everything is normal. if the internal piston is off center it will short the pin to ground. (putting the light on if it was connected)
89 Trans am GTA
Old 11-01-2014, 07:21 AM
ultraman's Avatar
will do a check with a multimeter thanks.
Old 11-02-2014, 04:56 PM
ultraman's Avatar
today i found the line from master cyl to prop valve was clogged with a dirt dauber nest.I cleaned out the line with some wire and it bled out perfectly.now if i can get the parking brake to work.
