Old 12-22-2011, 08:06 AM
ultraman's Avatar
ultraman ultraman is offline
Default headgasket
I installed a set of new headgaskets of unknown orgin on a 030 overbore 455,the gasketa protrude into the cyl,is this ok?
Old 12-22-2011, 08:11 AM
troy_barker's Avatar
troy_barker troy_barker is offline
into the cylinders? I think not but let others chime in!
Bring back my 67 GTO: Shes ALIVE as of 2-19-13
previously owned
78 Firebird
67 Nova
64 Nova
Old 12-23-2011, 08:10 AM
chiphead's Avatar
chiphead chiphead is offline
In a word: No.
The gasket edge that protrudes into the cylinder will glow like a candle. Not good.
Old 12-23-2011, 12:03 PM
PONTIAC DUDE's Avatar
Post
You want you head gasket to be at least .020 bigger in diameter then any part of the bore hole.
Old 12-23-2011, 10:09 PM
77 TRASHCAN's Avatar
The edge of the gasket is what seals the combustion event, without that seal, the gasket will leak. It would be a mess within the first minute or two of operation.
Make sure the gasket you use, fits the head and the block, as Dude, stated...
Each manufacturer has something in that edge layer that is compressed when the gasket is torqued down, making the seal needed.
Shut it off
Shut it off
Old 12-24-2011, 10:36 PM
rod cole rod cole is offline
Default Victor
My victor-reinz gaskets did that tried two sets both the same put felpro on fit perfect. Victor did not seem to care. Rod
