moldsmobile leaks oil
my 403 trans am leaks oil at the rear of the valve covers i,ve tried everything to stop it with no luck.the oil drains are not stopped up. please help with any suggestions.
Sheet metal valve covers often become distorted from over-tightening. Remove the covers and flatten the area around the bolt holes with hammer & dolly.
1969 GTO hard top ~ Std bore 400, '70-RA3 block, 670 heads, Bal. & Blue... M22, 12-bolt w/3:55s |
thanks GRX I will check that out.
Sure thing.
Your "dolly" can be anything. For this procedure I typically employ a piece of steel bar stock clamped in a vice.
Use a good sealant after you straiten them. just barely bolt them down and let the sealant set then tighten the bolts(just barely) and USE lock tight so they don't back out. And spreaders if you have them.
Why is he not suspended? |
