head gasket question
are all pontiac head gaskets interchangeable?350-455?
No.
The smaller bore sizes call for a smaller fire ring that corresponds with the bore size. If you use a 350 gasket on a 455, the gasket will over hang the 4.151" bore (or larger after boring) and cause hot spots (detonation) and sealing problems. Using a 455 gasket on a 350 will cause combustion/efficiency issues with the large fire ring that is way too large for the 3.875" 350 bore size. |
thank you Bman,i had an open gasket set and i put 350 gaskets an my 455 lucky i can fix this ,the engine is out.You are a lifesaver(wintogreen) HAHA.
